As with many things in life, bigger is better.
If you can fit 140's, use 140's.
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4816513
It depends on what you can fit in your case, what kind are you planning on buying?
Other than that, bigger is better like Real_PhillBert said. It also comes down to whether you want performance or low noise, and price.
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4816525
Be Quiet! Silent Wings 2's are good
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4816610
Scythe/Servo Gentle Typhoon
I7 4790k @ 4.6Ghz 1.288V                 Corsair Vengeance 12GB Cas8                          Overclocker Thug life
MSI-Gaming-7                                       Corsair Sandforce GT 120gig                             http://pcpartpicker.com/p/R2Jb6h   (Current Build)
OCZ Vertex2 60gig                               Corsair F60 60gig
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4816618
Hi I am looking to build a reasonable silent PC the quieter the better but i want to know that the fans i am buying will be well and and silent. I know noctua make very good fans so at the moment I have gone with some of their industrial ppc range but i know that they are not the quietest fans so I can either g with Be quiet silent wings 2 or cougar vortexes.
Which ones would you recommend and if you have any other ideas could you please say.
Thank you!
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4818710
My build is a silent gaming/workstation build and my budget is between 2000 and 2500 dollars maybe I could go a bit over.
The best way to do this: get mid tower case, fanless psu. As for drives I would go for wd green, they're a bit slow, but quiet enough. As for fans, I would add 1 noctua cpu fan and, probably, 1 intake fan with pwm (also noctua).
But, if u wanna go gaming, u will 100% need a psu with fan, so I would recommend any seasonic psu, they're the quietest I've ever seen.
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4818859
Oh right at the moment I have a seasonic fanless 520watt power supply and a noctua heatsink. Wil I be able to game with that power supply? (at the moment my system is running about 370 watts). I went on a power supply calculator for that reading.
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4818871
Depends of the efficiency. If it's 80+ - yes, of course.
It's not recommended to use like 95+% of your psu power, but u might be fine.
Can't really imagine what u can do else here, I'm using 1-fan setup for my home NAS server, but it just doesn't heat as much at all.
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4818882
It'll be fine.
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4819244
Hi what would you guys recommend as quite well build silent fans?
thank you!
Please list your specs, where you're shopping/located, and budget.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Will these fan's provide adequate cooling for a gaming/workstation build with slightly overclocked parts?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553016
Cougar Vortexes are good but the linked pricing is pretty horrid.
https://linustechtips.com/topic/354695-fan-decisions/#findComment-4831361
