I just installed hwmonitor on my NAS because I was curious what temperatures things were hitting and I saw that my motherboard temperature is really high (115C). I've never seen anything get that hot before. I have attached a picture
Im guessing this isn't normal? What could I do to diagnose the problem or to fix the issue?
https://linustechtips.com/topic/353802-motherboard-temperature/
That looks like an error if not shut that thing down!
My Asus board gives me an error if I try to open HwMonitor saying there is an issues with sensors, they give inaccurate readings.
https://linustechtips.com/topic/353802-motherboard-temperature/#findComment-4808225
Turn of your NAS as fast as you can, without changing the stress level (to retain heat, if its there) then feel the spot that's reporting that.
If you burn yourself the probe was right, you should've listened to it in the first place, just like when your mother told you to not date that one girl. If it doesn't burn you, the probe was lying to you, like that one girl your mom told you not to date.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/353802-motherboard-temperature/#findComment-4808245
-snip-
I run many more drives than that... never above 100 degrees Fahrenheit.
I'd wager it's just a broken probe, OP.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/353802-motherboard-temperature/#findComment-4808248
wat
https://linustechtips.com/topic/353802-motherboard-temperature/#findComment-4808288
wat
What? Makes perfect sense.
https://linustechtips.com/topic/353802-motherboard-temperature/#findComment-4808300
It's an error in the reporting software. If your board was 115C it wouldn't be functioning, or at the very least you would smell the distinct odor of plastic melting.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/353802-motherboard-temperature/#findComment-4811096
