[Troubleshooting] Downgrading from ATX to Mini-ITX
Demos
I'm wanting to downgrade from my very spacious Arc Midi, to a Bitfenix Prodigy with an Asrock Z77E-ITX board.
When I do this, will I have to do a fresh install of windows? Or just remove all the Motherboard drivers from my current SSD? Thanks!
Here's my current set up, If you see any incompatibility, give me a yell!
Intel Core i5 3570k
Antec Kuhler 620
Gigabyte GA-Z77-D3H
Corsair Vengeance 8GB
Samsung 830 Series 128gb SSD
Seagate Barracude 1tb HDD
Sapphire Raedeon 7870 OC Ghz Edition
Antec High Current Gamer 620W PSU
Fractal Design Arc Midi
CASE: BitFenix Prodigy | CPU:  i5 4570| CPU COOLER: Noctua NH-U12s | MOTHERBOARD: Asus H87-I Plus| RAM: Muskin Blackline 8GB | SSD: Samsung 830 128gb |
SSD: Samsung 840 128gb SSD(Games) | GPU: Asus R9 270X DCUII | PSU: Seasonic 660w | MONITORS: LG 23" IPS 5ms |
You'll have to do a fresh installation but also if you have Windows 8 OEM then you can reinstall it by using the product key but your using Windows 7 then you'll have to buy a new copy of it.
