Water cooling a 960
Go to solution Solved by STRMfrmXMN,
I do wish I could water cool or phase change cool my chair, gets hot sitting in it all day.
I really need to get around to watercooling my sidewalk. Damn that thing gets hot in the summer.
Yay I have two gigabyte g1 gaming 960s on the way for an upgrade for a client and I need to water cool them. I really have little experience with wc. So could someone tell me where I could find a vga block, how many rads if I also am cooling a cpu also any pump suggestions with finally serial or parallel
"This is a bad idea"
https://linustechtips.com/topic/350362-water-cooling-a-960/
please tell your client that stupid isn't even the right word to WC a 960, custom loop will cost about 400$ if you are going cheap on it
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766077
Why would you ever water cool a 960... Their's literally no point...
I doubt they even make blocks for it...
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766078
Should i water çool my hd 5450 too?
OP lol not worth it .
Waterçooling is for the 970 and 980 çards and even then its a waste of money for most people.
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766087
Agree with the others, there's no point in water cooling it. There's really no point in water cooling most of the 970's
Would you water cool my phone while you're at it?
And does anyone even make a water cooling block for a 960? I kinda doubt it.
Dubs are better than subs
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766092
Do they even make blocks for it? That sounds like an immense waste of money.... its like getting a custom loop for an i5.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766103
Does anybody make a watercooling block for the Antec BP350 PSU I have? Perhaps I could watercool my dogs....
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766112
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766115
Not that I can see. If the client was foolishness enough to insist on a full water loop Ek Thermospheres would have to be used and even then the VRMs would be exposed and additional heatsinks would have to be bought.
OP, seriously. Don't do it.
Steve
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766116
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766121
Ok, well there goes a lot of commission ;)
It would be an immense waste of money and there aren't any blocks for the 960 let alone the G1. You'd have to get ones that only cover the actual GPU and would look no as aesthetically pleasing as leaving the stock cooler on.
Steve
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766126
Why not make it out of ice?
I like where your mind is at.
I mean, if they really want it, do it. But as far as I know, no one makes a block for the 960's because they don't need it, ever. My 970 barely generates heat under full load, running three monitors for a single game. Hell, the monitors generate a greater volume of heat than the GPU does.
Indeed
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766131
Indeed
Now that I think about it....
I live in Oregon and it rains a lot. So I get watercooling pretty much year round xD
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766145
Just don't try collecting and storing that rainwater, apparently that is theft, because the government now owns the rain.
http://cnsnews.com/news/article/oregon-man-sentenced-30-days-jail-collecting-rainwater-his-property
(sorry for going off topic)
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766155
Maybe a ghetto cooler? Get a H80i, strap it on with zip ties and bingo you got a watercooled 960.
I remember linus doing a showcase on something like this in a NCIX video.
~~~SnapDragon~~~
| CPU: AMD Ryzen 9 9950X3D | CPU Cooler: Gigabyte Aorus Waterforce X II 360mm |RAM: 2x32GB G.Skill Trident Z5 Neo RGB 6000MHz | Mobo: Gigabyte X870E Aorus Xtreme X3D AI Top  | Storage: Samsung 9100 Pro 4TB + Samsung 990 Pro 4TB + Samsung 870 Evo 4TB + Samsung 870 Evo 2TB | Graphics Card: Gigabyte RTX 5090 Aorus Master 32G | Case: Lian Li Lancool 216 | PSU: Seasonic Vertex GX-1200 |
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766164
I suggest watching this....
https://linustechtips.com/topic/350362-water-cooling-a-960/#findComment-4766189
