How to add fans if ur motherboard doesnt support more than 6 fans
Solved by WoodenMarker,
whats the optimal number of fans in this case
its my first time so im quite inexperienced
Assuming you're using a single tower heatsink, you'd probably be good with 8 total fans: 3x on the graphics card, 1x in the psu, 1x on the heatsink, 2x 140mm's for front intake, and 1x 140mm for rear exhaust.
Featured Topics
ThatGuyEddy ·
Posted in Troubleshooting1 -
dani7 ·
Posted in New Builds and Planning2 -
6
laviRZ ·
Posted in General Discussion4 -
Sveeno ·
Posted in LMG Sponsor Discussion0 -
16
kris.narym ·
Posted in New Builds and Planning1 -
1
2
Pove ·
Posted in CPUs, Motherboards, and Memory9
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
