So I'm building and new budget gaming pc, and I was going for a micro atx motherboard. I am going to use a radeon r9 270x or an r7 260x and a pci express port for the wifi adapter (the really small pci express port). The problem is where I would put the gpu and the wifi adapter are right next to each other. So will they fit together?
motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128565&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/348898-wifi-and-gpu-help-plzz/
No, it won't fit. Since both graphics cards are dual slot, they will cover the small PCI-E slot. Sorry :(. HOWEVER, you could get a PCI (not PCI-E) wifi card and use that
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/348898-wifi-and-gpu-help-plzz/#findComment-4748319
