Fan 1 and 2 with SP120's. Getting more air through the heatsink will help and air is hard to move over drives and cables so the extra static pressure will help.
This.
Also, add an extra fan above fan 1
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4738990
Fan 2 will definately need a Static flow fan so SP120 .  Fan 1 is a bit more problematic,  but as a static pressure fan usually works in any situation I would also have an SP120 in this position.
Fan 4 doesn't add or detract from flow as it is completely seperated from the case internals whilst 2 only blows through the heat sink  so 1 = in and 3= out but as it gets a LITTLE help from 2 you have slight negative pressure. To get proper positive pressure I would add another intake fan probably at the front (can you mount two fans at the front), so the other fan would be beside Fan1
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4739055
No I can't fit a second one
Akkus Kursat
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4739225
What about changing that 120 for a 140?
Every little(very) helps
The ones you have seem to have purple lighting/LEDs so, perhaps:-
http://www.scan.co.uk/products/140mm-corsair-air-series-sp140-purple-led-high-static-pressure-fan-single-pack
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4742504
I already have ordered them, but still thanks.
This is my first PC build so for a future upgrade maybe a 140mm fan, who knows
Akkus Kursat
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4747563
I bought new Corsair SP120 fans and I installed them as shown on the picture.
I have 2 fans that I don't use, so I thought installing the standard CoolerMaster CPU cooler back on its place and installing SP120 (2) at the back of the cooler, because after installing the SP120 it didn't cool that well as with the standard fan
What do you think? Should I do it different or is it okay?
and what can I do with the other fan that I don't use?
post-180428-0-93609000-1429188095_thumb.
post-180428-0-40996100-1429188104_thumb.
Akkus Kursat
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4751665
You can save the unused fans for later.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4751785
Maybe another one at the front and one a top or bottom.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4751797
^^^^ This, if your case support it then put it there, just make sure the airflow is good.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4751804
The blackish COOLER MASTER one looks like a Static pressure fan but the clearish one has the looks of an airflow one, perhaps mount the SP one at the front and the air flow looking one at the bottom (is there an intake area in the area between the PSU and the hard drive cage?) where it only has to fight the intake filter.
  Doesn't look like there is enough space above the CPU cooler for another fan, but if that is all there is...
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4751818
I want to install a second one at the front, so there is space but when I install a second one the cables get in the way (at the front), and no I don't have space at the bottom or top :(
I'm gonna upgrade to a NZXT H44 when I can find the money.
So this is want to do (from right to left) Case fan 1 > SP120 (2) > CoolserMaster Fan > SP120 (1) and maybe a second one at the front if I can fit one. I'm gonna try once more
Akkus Kursat
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4751946
Then route the cables so they aren't "in the way"( extensions are availlable if the length of the cable affects the routing).
http://www.amazon.com/3-pin-Power-Extension-Computer-18inch/dp/B0055LVE0E
or PWM
http://www.amazon.co.uk/Akasa-AK-CBFA01-30-PWM-Extension-Cable/dp/B003VYB76I
You could of course break out the soldering iron and extend the cables yourself.
Edited to add :-
How about a fansplitter from  fanheader that you use to both front fans?
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4752107
or PWM
Edited to add :-
I mean the cables of the front panel itself, so USB 3.0, audio,...
Akkus Kursat
https://linustechtips.com/topic/348138-which-fan-and-where/#findComment-4752174
