Molex to 3 pin voltage
By
Guest
in Cooling
in Cooling
Solved by Guest,
Yes. And btw you can switch the two leads on the molex around to turn it into 7V if needed...
Okay great, thanks!
ConfigThis ·
2
3
1
11
5
2
5
play_circle_filled
Latest From Linus Tech Tips:
Why it Was Almost Impossible to Put a Computer in Space
play_circle_filled
Latest From ShortCircuit:
I’m kind of an iPad hater, but this is MAGICAL. - iPad Pro M4
