So earlier I was soldering some wires to a switch (very newbie to soldering), and spent maybe 10-15 minutes working on soldering the wires to it, and was using a window fan that was leaning against my wall blowing air towards me and the thing I was soldering, and had the window open.
I've got some weller 100/140w soldering gun that I was using as I don't have an actual soldering iron, so I ended up having to sort of lean over the switch (the switch was secured into the top of a project box, so I was holding it between my knees) and have some Bernzomatic electrical solder (silver bearing rosin core solder, contains tin, copper, and core flux), I probable used around the size of a large pea of solder.
I ended up breathing in some of the fumes, and have read a couple different things online, but am unsure of what is true, and such.
1. Is this small exposure to lead-free rosin core solder harmful?
2. How much exposure for how long would you estimate would be harmful?
3. Are the fumes from lead-free solder more harmful than leaded solder fumes?
I'm not seeing dots or hallucinating or anything like that right now (its been about 2 hours since I stopped soldering), though I was having some slight irritation in the lower front area of my neck (which was there for around 10-20 minutes after I stopped.
Another question/confirmation on what I heard:
Is it true that exposure to lead-free solder fumes can lead to pneumonia or 24-48 hour long flu like symptoms? If it is true, how much exposure would be required for that to happen? Was I exposed enough for it to happen to me?
Thanks!
(Note: Most of the time I would hold my breath when soldering the points, and would continue to do so for a couple seconds after I could no longer see the smoke/fumes from the solder, though there were a few times when I didn't hold my breath and am pretty sure I breathed in some of the fumes)
https://linustechtips.com/topic/347633-soldering-help/
A lot these effects that you've read about are from long continuous exposure to soldering fumes, like if it was part of your job. I've done plenty of it and haven't noticed any side effects.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732741
I wouldn't worry, I have treated my lungs to various types of solder fumes over the years and so far I'm still alive and kicking. Its certainly not healthy, but you'll live  ;)
Alright thanks, glad that its not gonna end up being horribly harmful to me :P
(Kinda went into a panic mode about it from my damn anxiety :/)
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732756
I do a lot of soldering and I work very close to people who are constantly MIG and TIG welding aluminum. With lead-free solder there is no real danger unless you sit there and inhale a whole lot of the fumes. Even then I don't think you'd be much the worse for wear, it'd be like smoking a couple cigarettes maybe.
Get a third hand. http://en.wikipedia.org/wiki/Helping_hand_%28tool%29
It will make your life so much better.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732772
I've done plenty of soldering, even in non-ventilated rooms and I'm as healthy as ever. Just as long as you're not sucking in the fumes all day, every day, it's no worse than cooking over an open fire at a campsite. You'll be fine. Just don't stick your soldering iron in a hubble pipe.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732850
Been sucking up solder fumes for quite some time. Still alive  :lol:
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732859
Yeah I've wanted to get a third hand for a while, though I hardly ever solder stuff so I decided it's not something I really need.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732868
Is not the lead in solder that can damage your lungs, is the fumes that come from the flux.
You never point the fumes towards yourself like you did with the fan.
If you want to have an easy time soldering, don't use lead-free solder, get yourself some 60/40 stuff and make sure you get the thin one, 0.5mm is good.
Leaded 60/40 solder is not going to kill you unless you eat the thing, flux fumes are a nasty thing though don't breathe those.
The stars died for you to be here today.
A locked bathroom in the right place can make all the difference in the world.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732931
Yeah, the main thing that I was worried about with the lead-free solder aside from the flux fumes was the tin.
One of my friends who is going to college for electrical engineering suggested 60/40 leaded solder to me when I was talking to him a little while ago.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4732969
60/40 is easier to work with, you can start to solder right away, just don't breathe the flux fumes and you'll be ok.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4733006
Nope. 63/37 is way easier to work with as it is a eutectic alloy. I personally do not use that lead-free or 60/40 crap.
60FPS Microwave
https://linustechtips.com/topic/347633-soldering-help/#findComment-4733032
alright :P
I found that the shit I was using ended up going onto the pins of the switch, but that was about it, once it was on it didn't want to melt enough for me to get a wire through the hole in the pin.. (Thinking I probably should have put the wire through first, then added solder)
I think ill just use some heat shrink tubing and hot glue next time, cause I can clean that shit off pretty easy compared to solder. (Its all going in a project box where none of the wiring will be really moved at all.)
https://linustechtips.com/topic/347633-soldering-help/#findComment-4733038
I have been soldering since 6th grade (freshman in college now). I haven't had any issues with inhaling fumes before, but I am probably going to propose a fume extractor for work when the company I work for moves to a newer building
As for tips for soldering,
1. Lead free solder is a PITA because it requires such a high temp to melt (though it shouldn't be hard with a 100w or 140w gun)
2. For DIY stuff that is with thin wire/pcb get a 50w adjustable station like this http://www.mcmelectronics.com/product/TENMA-21-7945-/21-7945
3. Get something like 60/40 solder (or whatever combo you like best)
4. Get a set of helping hands (or 3rd hand). Also, a panavise comes in handy. You can find similar products for $15 on amazon.
http://smile.amazon.com/Bessey-BVVB-Vacuum-Base-Vise/dp/B0057PUR88/ref=sr_1_8?ie=UTF8&qid=1428983637&sr=8-8&keywords=vise
or some sort of simple clamp. These come in helpful while soldering to switches and stuff, or just for holding wires so you can tin them easier. Just make sure to not get super strong ones. You don't want them to break what they are holding
http://smile.amazon.com/WorkShop-83896RP-4-Inch-Spring-4-Piece/dp/B00J4DGA9O/ref=sr_1_10?ie=UTF8&qid=1428983679&sr=8-10&keywords=clamp
5. get soldering flux. The liquid is awesome, but goop works well too, its just a little messier (but cheaper).
https://linustechtips.com/topic/347633-soldering-help/#findComment-4733297
How about solder with flux already added to it instead of solder and flux separate?
https://linustechtips.com/topic/347633-soldering-help/#findComment-4733310
Almost all solder for electronics work already has a flux core but it is very hand to have separate flux.
There are times when you need to apply a little more flux  when the joints are a bit oxidized.
And also, try using 63/37 solder. Its way better than 60/40 especially when you don't have a helping hand. It solidifies almost instantly so you don't get cold solder when you move the joint while cooling.
60FPS Microwave
https://linustechtips.com/topic/347633-soldering-help/#findComment-4733535
I find that having separate flux can be very useful in certain situations. Especially if you are using a thicker wire than usual. Flux in solder helps, but having it already coated on the wire makes everything go super easy. The only downside is that it produces a ton of extra smoke and it is easy to make everything look burnt if you keep the heat there too long. The liquid stuff really only takes like a drop for most connections. The goop stuff takes a little more, but it hard to get just a little bit of that anyway.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4736735
I will have to get some 63/37 solder. Never used it before (to my knowledge), but it sounds way better. One of the things that I frequently have to solder at work is very tricky to get everything still long enough for the solder to cool and solidify nicely.
I haven't tried this yet, but it looks handy for soldering to a pcb. But it might not dispense solder fast enough.
https://linustechtips.com/topic/347633-soldering-help/#findComment-4736759
 I think prolonged exposure to industrial fumes and similar can cause problems in later life: i.e. chronic pulmonary obstructive disease.
As far as I know the affects are cumulative and the symptoms worsen as the body ages.
Really and truly you should try and avoid inhaling stuff like that. :0/
I'm not sure if there are exceptions or if some stuff is worse than other stuff, or how bad solder fumes are specifically (if at all) or how much of all of it you need for it to have a noticeable effect, I just try and avoid inhaling as much crap as I can just as a matter of course. :0/
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/347633-soldering-help/#findComment-4736840
