Really not sure about this one. Anyone have an idea?
https://linustechtips.com/topic/346639-physics-help-needed/
This not the PhysX I was looking to discuss. Damn!
Sorry no rigid body discussion going on here .
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720008
Use ideas about quantum behaviour of photons.
What do you know about the quantum behaviour of photons? And how does it relate to this?
Edit: or in other words...what did the course teach you about the quantum behaviour of photons and how can you use it to answer this question? ;0)
Clue: Look back through your notes or consult the text books.
(not information I have) :0/ :shrug:
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720053
So you have to use the concept that light acts as a wave and a particle, but I don't know how the curvature of the dish would be affected by this. Good luck, op.
CPU: Intel i5-4690K 3.5GHz Quad-Core   Mobo: Asus Z97-A ATX LGA1150   Memory: G.Skill Ripjaws X Series(2x4GB) DDR3-1600   GPU: Asus Strix OC GTX 970   HDD: WD Black 2TB - 7200RPM   SDD: Samsung 840 EVO 250GB   PSU: EVGA 750W 80+ Bronze - SemiMod   Case: NZXT S340 (Black)
PCPartPicker: http://pcpartpicker.com/user/PortedOasis/saved/fhdG3C
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720152
Well I found the mark scheme it tooks ages to find... and it is just not that good of an answer to be honest: to create many paths of equal length / trip times same so high probability photons arrive. I guess it makes sense but doesn't really relate to the quantum nature of the photon, I guess it does slightly in the fact that it can travel many different paths but still...
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720344
To be completely honest with you I've not studied this, I kind of just assumed the answer would be more forthcoming if looked at from the angle hinted at in the question?
Personally, based on my limited (and very basic) knowledge, I'd say it would need to be angled to reflect the photons into the detector (like a lens or a concave mirror that can focus light). Where the quantum behaviour of photons enters the equation I've really no idea, I kind of just assumed it must do at some point for the question to ask for the answer to relate to it?
Is it something you can ask a tutor about or does it actually count towards your grade?
It seems strange that they'd require an answer that isn't addressed by the information in the course, but who knows?  :wacko:
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720496
To be completely honest with you I've not studied this, I kind of just assumed the answer would be more forthcoming if looked at from the angle hinted at in the question? :0/
Personally, based on my limited knowledge, I'd say it would need to be angled to reflect the photons into the detector (like a lens or a concave mirror that can focus light). Where quantum behaviour of photons enters the equation I've really no idea, I kind of just assumed it must do at some point for the question to ask for the answer to relate to it?
Is it something you can ask a tutor about or is this actually a marked assessment?
It seems strange that they'd ask you a question that isn't addressed by the information in the course but who knows?  :wacko:
Well this is a very old past paper, like 10 years old at this point, most likely the syllabus has changed quite a bit, it covers similar things but not all of it is similar.
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720513
Okay, well that could explain it then.
Do you have any idea what the answer that they're looking for is? :confused:
It seems weird to me that they'd give you that as a revision question. :0/
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720545
Well I'm redoing my last year in college, so I'm doing most the work at home, however I can go into school if I need some help, I've been doing fine so far. Just last year I didn't really put any effort into my work and came out with grades that were too low for where I wanted to go. Doing work independently is much easier I feel, as you can go through at your own pace. However it's easy to get distracted with all the things at home, mostly just pissing around on the forum and on my PC in general.
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720597
Yeah, I know what that can be like. There's a ton of stuff I should be getting on with and I"m still sitting here. :0/
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720616
Only thing I could come up with is the wave-particle duality. So if photons were just particles, then any sort of curvature, even a steep parabola would work. But because photons also behave like a wave, the parabola has to be shallow enough to catch lower frequencies? Just a thought. I don't actually know if it works that way though. I'm sort of connecting the Rayleigh scattering with the wave-particle duality.
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4720973
I was going to suggest that's why the struts don't interfere with the image but I guess that's not really about the curvature? :shrug: :DryPhisicsLols:
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4721107
LinusPhysicsTips
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4721190
The detector can only detect light that is higher a certain photon/area, so if the dish was bigger and curved, then it redirects more photons into the same area which would then make a higher photon/area and therefore, better chance of being detected.
https://linustechtips.com/topic/346639-physics-help-needed/#findComment-4721210
