Problems with my HP desktop
Solved by VioDuskar,
4. Do you think any other upgrades are needed?
Buy a new computer, there isn't much point upgrading this one.
Get a whole new PC!
You will be best just to get a new PC and re-purpose that one as a game server or something.
OP, get a new PC. build one. watch linustechtips videos on youtube he'll teach you how to build one.
this community will also help you pick parts for your new build if you give us a budget, currency you use, and what you want the computer to do.
we're here to help you, and by the looks of it, you're going to learn a lot here.
also, that case won't allow a normal GPU to fit in it, and the PSU won't have the 6/8 pin connectors a GPU would need for power.
