Build for a friend
Go to solution Solved by zappian,
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  (£55.38 @ Amazon UK)
Motherboard: Gigabyte GA-F2A58M-HD2 Micro ATX FM2+ Motherboard  (£32.50 @ Aria PC)
Memory: GeIL DRAGON 8GB (1 x 8GB) DDR3-1333 Memory  (£48.10 @ More Computers)
Video Card: Palit GeForce GTX 750 Ti 2GB StormX OC Video Card  (£103.20 @ Kustom PCs)
Case: Zalman ZM-T4 MicroATX Mini Tower Case  (£14.50 @ CCL Computers)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  (£31.74 @ CCL Computers)
Total: £323.76
Generated by PCPartPicker 2015-04-09 21:33 BST+0100
So its about time that my friend got himself a PC to replace his current laptop. I was just wondering if anyone could help him in picking the parts for his first build...
Information:
-Budget £300
-Plans on using it for Light gaming & designing.
-Wants it to be small form factor as he has limited space.
Any help would be greatly appreciated!
Thanks in advance...
https://linustechtips.com/topic/344771-build-for-a-friend/
Is a copy of Windows or any peripherals needed?
Are there any parts that can be salvaged like a storage drive from the laptop?
https://linustechtips.com/topic/344771-build-for-a-friend/#findComment-4696413
I have Windows 8 on a USB so I can install that for him & I also said I would give him an old keyboard of mine. Im pretty sure the only thing he needs is the pc itself...
https://linustechtips.com/topic/344771-build-for-a-friend/#findComment-4696438
Total: £323.76
https://linustechtips.com/topic/344771-build-for-a-friend/#findComment-4696514
Total: £323.76
I have just sent him this parts list and he seems pretty happy with it! Thanks for posting...
https://linustechtips.com/topic/344771-build-for-a-friend/#findComment-4696583
You can also get a r9 270 instead.
I just picked the 750 ti to get a cheap PSU with no worries.
Glad you liked it.
Cheers.
https://linustechtips.com/topic/344771-build-for-a-friend/#findComment-4696601
