Random freezes - most likely gpu problem
Solved by YoYo155,
It's 320!
Try uninstalling them then when reinstalling older drivers, I recommend 314.22, choose custom install and check "clean install"
also uncheck nvidia update & geforce experience.
Featured Topics
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
2
7
2
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning8
