Need help with this one.
You.. You only want to know the difference?
I believe for loops are like.. For everyone instance of something
(Lets say for example, for every player in a game, it happens once.)
And while loops, happen while something is true.
Example: while there is more than 2 players in game
I believe it works like that
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4684984
while (condition)
{do this thing}
for(initializer; break condition; incrementor)
{do this thing}
Edited by alpenwasser
code tags :)
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4684991
any while can be a for, and any for can be a while. for example, a program that counts to 30, and prints what X is.
for(x=0;x != 30;x++){cout << X << endl;} x=0while (x != 30){x++cout << X << endl;}
oh, this in in C++ BTW.
in normal C the only change would be that the line
cout << X << endl;
would become:
 printf (" %d  \n" ,X );
code tags :)
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4685010
Need help with this one. Every multiples of 3 should be "Wowza" and "Cowza for 5's.
... etc up to 100
Follow your Thread.
you need a while loop, with if statements in it.
you also need to use the modulus operator "%" which gives the remainder of an operation.
so 6%3= 06%4= 266%11= 010%4= 2
understand?
your program needs to use the modulus operator to detect when a multiple is divisable by 3 and 5, so the modulus would yield 0 when those conditions are met.
if (x%3 = 0){cout<< wowza}
code tags :)
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4685102
Ah the good old fizzbuzz test: http://c2.com/cgi/wiki?FizzBuzzTest
What you'll need to know about for this program is the following:
- If statements
- The modulo operator
- Loops (both for and while loop will work)
I always recommend programming in baby steps. How big a baby step is, depends on how experienced you are.
Since I see that you are just beginning let's take really small steps
first let's write a program, that checks if a number is divisible by three.
We can simply use the modulo operator and an if statement for this:
int number = 6;if(number % 3 == 0) //check if the number is divisible by 3  printf("This number is divisible by 3!\n");
no let's take that program, and chang it so first we check if it's divisble by 3, and if it's not if it's divisible by 5
int number = 10;if(number % 3 == 0) //check if the number is divisible by 3  printf("This number is divisible by 3!\n");else if(number % 5 == 0) //if it's not, check if it's divisible by 5  printf("This number is divisible by 5!\n");
Now a bit more tricky we have to know if it's divisible by both 3 and 5. Naturally you would just add another else if to the end, but that won't work. That is because the program will find it's divisible by 3, and then skip over the other checks, so we have to check for that first.
int number = 30;if(number % 15 == 0) //we do the modulo of 15 here, because any number that is divisible by both 3 and 5, is divisible by 15 printf("this number is divisible by both 3 and 5!\n");else if(number % 3 == 0) printf("this number is divisible by 3!\n");else if(number % 5 == 0) printf("this number is divisible by 5!\n");
Now we have to put this in a loop to check a bunch of numbers. I'll show how to do that using a while loop.
int number = 1; //the starting numberwhile(number <= 100) //only run while we haven't printed 100 values{  int number = 30;  if(number % 15 == 0)  //check if the number is divisible by both 3 and 5    printf("this number is divisible by both 3 and 5!\n");  else if(number % 3 == 0) //check if the number is divisible by 3    printf("this number is divisible by 3!\n");  else if(number % 5 == 0) //check if the number is divisible by 5    printf("this number is divisible by 5!\n");   number = number + 1; //increment the number by 1}
This program doesn't fulfill all the requirements yet, but can be easily modified to do so
Edit: code tags
PS: this code is writing in C, but is also valid C++, I am not sure what language you are using, but the concepts will be the same
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4686615
Batch script
@[member='Echo'] offfor /l %%i in (1,1,100) do (set /a "is3=%%i%3"set /a "is5=%%i%5"set "return=%%i"if %is5% equ 0 set "return=Wowza"if %is3% equ 0 set "return=Cowza"if %is5%%is3% equ 11 set "return=WowzaCowza"echo %return%)
A riddle wrapped in an enigma , shot to the moon and made in China
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4686623
They hardly teach the modulo operand in school, it's quite funny.
The other day my friend wanted to write a program that prints out even numbers, up to however many the for loop condition was.
I was like, errr.
if (number%2 ==0)
  printf("Even\n");
else
  printf("odd\n");
He's in a beginning java class. But either way, I was hardly taught it. I figured it out myself.
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4694965
f1=0f=0var array = [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,43,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100]f=array.lengthf1=f-1z=0g=0while (z<f1) {g=array[z]if (g%3==0 && g%5==0) {array[z]="WowzaCowza"} elseif (g%3==0) {array[z]="Wowza"} elseif (g%5==0) {array[z]="Cowza"}document.write(array[z])document.write("</br>")z++}
I would do it like this in javascript but keep in mind that there is a lot of solution to this problem. you don't need to set all var to 0 just the z it's more of a not for myself
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4695354
I was like, errr.
if (number%2 ==0)
  printf("Even\n");
else
  printf("odd\n");
Most beginners classes assume no prior programming knowledge so all the basics are usually mentioned. The modulo operator is likely shown when the basic operations are shown. It's common to mention it after or along with the division operator. At a minimum they should tell you what it does with examples. They may or may not show common uses for it because they may want students to figure that out on an assignment (like the even/odd example).
Problem solving is part of programming after all and many times you need to use what you've learned in ways you weren't taught.
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4695410
I'm well past my beginning classes now though. Spring 2016, I'll have my BS in CS with concentrations in Software Eng and Comp info and Secu.
I just don't recall using modulo on any assignments/hws. Maybe it's just been a while and my memory sucks.
Learning on your own is also an important skill for programmers :P
It's entirely possible it just wasn't covered for you, it just seems odd to me. If you had a "Beginners Java/Python/whatever language" textbook for that class, I would guess it was at least covered there.
Either way, good luck on the rest of your degree.
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4695745
This seems like premature optimization. It'd probably be better if you wrote if (number % 3 == 0 && number % 5 == 0). A decent compiler should reuse the value of number % 3 and number %5 in the next two checks.
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4696417
There is so much unneeded excess and confusing code here, this can be achieved in a mere few lines, as i have done.
<script type="text/javascript">	for(var i = 1; i < 101; i++)	{		document.write(i);		if(i%3 == 0) document.write(' Wowza');		if(i%5 == 0) document.write(' Cowza');		document.write('<br />');	}</script>
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4698535
I'm usually saving all var for other purpose so I kept that habits sorry xD
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4704469
Sorry, I am a game/graphics programmer. I do these little things without even really thinking about them xD
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4719064
This is assuming you are using the standard namespace, which is a bad idea because it makes the code look messy and hard to read. it would be better to replace
cout << X << endl;
with
std::cout << X << std::endl;
Now it is clear that you are referring to cout and endl from the standard namespace and not something else. Using namespaces is a bad idea, period.
https://linustechtips.com/topic/343917-for-and-while-loops/#findComment-4720497
