Water Cooling gtx 970?
Solved by airdeano,
you'd prolly want to use the NZXT G10 and any Asetek (round pump) AIO, for
cost, the single (120/140mm kits) fan systems are sufficient.
970/980 are the same installation.
3
1
2
Gat Pelsinger ·
Posted in Programs, Apps and Websites2 -
MootEndymion752 ·
Posted in Member Reviews0 -
koko_1989 ·
Posted in Peripherals0 -
phundercat ·
Posted in Troubleshooting2 -
bravefighter1019 ·
Posted in Troubleshooting0 -
5
