More cores or less?
Solved by SteveGrabowski,
For editing, the CPUs from best to worst are probably
1. Xeon E7, Xeon E5 series (6 to 15 cores plus HT)
2. Enthusiast i7 series (6 to 8 cores plus HT)
3. Mainstream i7 and Xeon E3 series (quacores plus HT)
4. FX-8 series (octacores)
5. i5 series (quadcores w/o hypertheading)
Basically, moar corez all the way except for mainstream i7/XeonE3 over FX-8. Seems like it's hard to beat the incredible value an FX-8350 offers this use case scenario where you're editing video and images, unless you can afford enthusiast i7s or Xeon E5 or better.
