Program with CPU & GPU Temps on Taskbar
Solved by Syte,
CPU temps: CoreTemp when minimised
not sure on GPU.
Recommend against CoreTemp.
If you have a Intel CPU use RealTemp, it's absolutely amazing. It also is able to track GPU temps and you can put all cores and GPU core on the taskbar and colour them differently so you can tell which core is which.
Playgb2 ·
Posted in Troubleshooting0 -
1
1
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
play_circle_filled
Latest From ShortCircuit:
