I often get error 525 when trying ti access LTT. It happens at least once a day.
Yeah, I got it fairly often too.
I believe it's their host or something, but I'm not sure..
happens to me too. always wondered what the deal was and if i was the only one. i think canadia is trying to keep LTT from spilling country secrets.
or linus's guys need to work on their webhosting.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
It's likely that it's an issue with Cloudflare, the CDN that we use, because they have been having some issues recently. I will look into it though, but I doubt that there's anything that can be done.
Do you use an addon such as HTTPS everywhere? That error should only occur if you try to access the site over HTTPS, so you would be able to get around the issue by loading the site over standard HTTP.
HTTP/2 203
I wasnt abale to join the site for 3 days :o
