Ripping CD, CPU Usage and CD Speed
So I got the Super Smash Bro 4 Soundtrack (Red, Blue)
I usually rip the cd in FLAC and they don't take that much but I tried to used MP3 on highest quality setting on Foobar 2000(320kbps).
Total time it took to rip to mp3 (1hr 18min duration) and it took about 30min....
Is the ripping process getting throttled by speed of the cd it was burned at?
https://linustechtips.com/topic/336042-ripping-cd-cpu-usage-and-cd-speed/
Wait what?
People still use CDs? WHY?
What's it to you?
Maybe the fact that the process would be much faster using an external SSD or something as simple as a USB drive?
There's a reason CDs are no longer used by almost everyone...
So?
So?
So he could completely avoid spending an hour ripping audio to a CD and just spend a couple seconds using a USB instead?
lol
lol
Why would USB be involved at all? If it's a digital download there would be no transfer needed. But the OP has music on a CD and going on about how dated CDs are is not helpful and makes you look dumb.
To answer the OPs question:
What CPU is in your machine? Foobar has no way of knowing at which speed the CD was burned, and that isn't how it works anyway.
lol
I'm sure if he had all that music on a USB stick he wouldn't be using a CD. Maybe, just maybe, he's ripping from the CD in order to put it on a USB stick. That would be a novel idea, now wouldn't it?
lol
That's burning not ripping. Ripping is getting audio off of a CD not on it.
only reason i am ripping cd is because nintendo gave out in cd format?
Which is WHY I want to rip it and store as flac file on my computer instead of bulky cd
Wait what?
You missed the reason WHY i am ripping
That's what I figured. So back to the issue at hand, what CPU are you running? Because over an hour to rip a single CD is kind of ridiculous.
