Cpu temp problem
Solved by LogicalDrm,
Core temp
I've heard that AMD chips have really bad temp sensors in general. HWmonitor is one of the better monitoring softwares for AMD chips. If you want to make sure everything is ok in windows, check with that. But I wouldn't be too worried over it.
kerriya ·
Posted in Cases and Mods0 -
octester ·
Posted in Troubleshooting1 -
DavidPatrascu ·
Posted in General Discussion5 -
1
2
bill well ·
Posted in Peripherals0 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
play_circle_filled
Latest From ShortCircuit:
