H100i - leak "explosion"
Go to solution Solved by Norskertv,
Thank you for all your replies. I contacted the place from whom I bought the unit and they will replace it since it was a major malfunction and should not happen. The liquid is not and electrical conductor and for anyone finding this post having the same issue it will not ruin your components. however overheating whilst the cooling unit is broken can damage the components.
The warranty only covers the unit, Everything else is gonna be out ofyour own pocket since no company will pay for any damage like that.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569525
My h100i gave up today and I now have corsairs cooling goo all over my pc. I am trying to dry it and clean it best as I can but I need some advice as to if corsairs warranty covers their hoses popping off and if any parts are broken what shall I do from there.
For the getting the "corsair goo" off. I would open the side panel and lay it out flat so it will start to drip out the case. But I would wait a few days, or if impatient then use something to wipe it off and wait a few hours.
Also, I THINK there warranty covers that. Just tell em' and then they will say if you can or not. (for the H100i)
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569532
contact corsiar and they should repalce the failed unit
wow never seen a hose come loose
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569539
contact cosair and tell them what happened, it has been heard of these companies paying for new components as well as a pump before, they would never put that in there warranty though as you would get too many people trying to game the system
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569544
Well here is their Warranty guide: http://www.corsair.com/en-ca/support/warranty
See the following part:
Exclusions
This warranty does not cover problems or damage resulting from, but not limited to, any of the following:
  • Wear and tear associated with normal use
  • Any modification, abuse, accident, disassembly, misapplication, or unauthorized repair
  • Removal of any manufacturer label(s) or sticker(s)
  • Any improper operation, including any use not in accordance with any supplied product instructions
  • Connection to any improper voltage supply
  • Use of consumables, such as replacement batteries, not supplied by Corsair, except where such restriction is prohibited by applicable local law
  • Any other cause which does not relate to a product defect in materials or workmanship
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569576
I read that they had replaced components before but I didn't know if that was in situations where the house actually came off. I just saw it with someone who's unit was dripping for no apparent reason. Also pictures of the thing if it matters http://imgur.com/a/vUrdy
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569587
If you want them to cover other components under their warranty, make sure you take lots of pictures of everything BEFORE YOU DRY IT OFF to prove that you're not making it up.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569590
What the heck did you do to make a hose come off?
Did you twist the tubing?
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569669
just contact corsair explain what happened ask what they can do and go from there
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4569672
https://linustechtips.com/topic/335047-h100i-leak-explosion/#findComment-4570011
