4k build Help
Go to solution Solved by xnoobftw,
@techguru I have a micro itx board and I want to upgrade to an atx board with 2 PCIex16 slots for future upgrades.  My memory def needs a boost.  I have 16 GB of 1066 and want to up it to 16GB of 1600.  Also, you said the $999 GTX Ti was a waste, so what would you recommend?  I'm not keen on spending that kind of money when I won't be playing FPS games at all.
Your ram is fine. Reuse it. As for motherboard i suggest upgrading to one that allows SLI for future SLI of the titan X
Titan X really is the way to go if you want a long lasting beast of a gaming rig
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($95.99 @ Amazon)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard  ($129.99 @ Micro Center)
Video Card: EVGA GeForce GTX Titan X 12GB Video Card  ($999.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($114.99 @ Micro Center)
Total: $1631.66
Generated by PCPartPicker 2015-03-22 00:02 EDT-0400
I gotten you a 850 watts PSU (the best one too) for future SLI and OCing potential of both titan X
Your Ram really IS fine.
(IMO the build i gave you cannot be beaten)
Hi everyone,
I have two Dell 4k IPS monitors and want to build a rig to utilize them.  The thing is I don't have 5 billion doallras to spend on this rig.  My budget is $1500 I can stretch it to $1700 if need be.  I don't play FPS games at all but I do play MMOs like WoW.  My main games are Diablo 3, Starcraft 2, Path of Exile, Tomb Raider, Assasin's Creed, and plenty of RPGs.  I know with $1500 I can't get the ultimate best of the best but I would like to get as close as possible.
If you can provide me with a build that would get me 4k gaming at my budget please link me the build specs.  Thank you in advance.
https://linustechtips.com/topic/332121-4k-build-help/
i7 4790k
z97 high end board
16gb pc1600 ram
250gb ssd (samsung/ crucial)
2tb wd black hdd
nice case..probably cm stryker
nice high end air cooler from noctua
and probably a gtx 980 or a amd 390 (in a couple months)..probably would wait for the 390
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508387
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.99 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.98 @ NCIX US)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($37.99 @ SuperBiiz)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Micro Center)
Total: $1574.88
Generated by PCPartPicker 2015-03-21 08:48 EDT-0400
Best experience IMO ^
Titan X can be reused when you want a CPU/MOBO upgrade (which IMO shdnt be needed if you are just gaming)
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508418
There you go :) don't listen to those saying you need a million $ for 4k gaming, 1.7k are PLENTY.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($153.98 @ Newegg)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  ($222.49 @ Amazon)
Video Card: XFX Radeon R9 295X2 8GB Core Edition Video Card  ($659.99 @ NCIX US)
Case: NZXT Source 210 Window ATX Mid Tower Case  ($52.98 @ Newegg)
Total: $1633.39
Generated by PCPartPicker 2015-03-21 08:52 EDT-0400
sudo chmod -R 000 /*
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508435
if your not playing fps...4k gaming doesn't need 2 gpus right now ...a strong single card is good enough
and if you want you can always throw in a second one in a year or so
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508526
other then the assassins creed game...which btw..runs crappy on everything even at 1080p...those other games would be totally fine at 4k on a 980...tho I might wait for the amd 3x series
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508531
@seroth77
Follow your topics
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508606
Lots of rpgs require a lot of resources. Witcher 3 is an RPG, Assassin's Creed is an RPG, etc.
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508647
Total: $1574.88
^this^
Although i would spend a little more on a case and a motherboard since you can go to $1700
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508667
Hi everyone,
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($178.99 @ SuperBiiz)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($64.99 @ Mwave)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($39.99 @ NCIX US)
Total: $1697.90
Generated by PCPartPicker 2015-03-21 10:17 EDT-0400
^ you can switch out the noctua cooler for something cheaper for a 1.6k rig
 badges badges badges badges badges badges badges badges badges badges badges badges badges
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508795
Hi everyone,
Also, you realize your monitors only run at 30 hz, correct?
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4508853
It seems that the GTX Titan is the go to GPU for what I need.  I just hurts to sell the bulk of the build on a GPU but if that is what needs to be done then that is what it will be.  When is the AMD 3X series supposed to drop?   Also, will a 600W PSU be enough?  I've been reading reviews and it seems some say you need 1000W.  Is that a lie?
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4510216
I also have another question.  I have a Intel Core i7 - 2600k Sandy Bridge processor.  Is there a way to reuse this processor or do I need to upgrade?  I went looking for 1155 boards but I was very confused by what out there.  If I need to rebuild a new rig completely and that is my only choice then so be it.  If I can reuse this CPU then that would be even better.  What do you guys thinks?  Any advice is greatly appreciated.
@techguru @mushies1337 @xnoobftw @Wirbelfeld
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4510258
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4512566
if its an itx board..then yea maybe a change there
in theory your ram is fine..tho if you really wanna do 4k gaming...then yea that could use a boost as well
as for the card..I would probably wait for a amd 390...it should be the first single chip card that should give you 4k gaming on 98% of games at 40+fps
2x970's is another option as well..but you will get some games not working properly with the sli....
https://linustechtips.com/topic/332121-4k-build-help/#findComment-4512617
