So im going to get Alienware x51 ( 4th Generation Intel® Core i7-4790 processor, NVIDIA® GeForce® GTX 760Ti 2GB GDDR5 , 16GB Dual Channel DDR3 at 1600Mhz (2x8GB) ,256GB SSD SATA 6Gb/s + 1TB 5400RPM SATA 3Gb/s)  and how many FPS can i get from CSGO. Help thanks   :)
Alot.
And here comes the Alienware haters tsunami! Brace yourself!
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476220
many
Why... do you want an Alienware..
i5-4690k @ 4.2GHz | Asus Radeon R9 290 DirectCU II | Hyper 212 EVO | ASRock Z97 Extreme3 | Corsair Vengeance 8GB 1866MHz, Corsair XMS 4GB | 850 EVO 250GB, random 1TB drive | Corsair 200R | EVGA SuperNOVA 750W | Rosewill RK-9000BR | Logitech G700s | Logitech G930 | ViewSonic VG2427wm, Dell S2209W, Dell S2009W
Dell Inspiron 3147
Latitude E5420, Samsung 840 EVO 250gb, 12gb RAM, 1600x900 display
Pentium G3258 @ 3.2GHz | WD Red 2TB x3 in RAID-Z, Crucial MX100 128GB(cache drive) | Fractal Design Node 304 | Gigabyte GA-H97N-WIFI | Crucial Ballistix Sport 8GB | EVGA 500B
HTC One M8 64GB, Droid Razr M
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476222
Alot.
He is telling to techies, that he want to buy pre-build computer. What do you expect?!
1. Don't do it
2. You'll get enough, but I doubt that CS:GO is only game you are playing, or going to play.
Laptop: Acer V3-772G  CPU: i5 4200M GPU: GT 750M SSD: Crucial MX100 256GB
DesktopCPU: R7 1700x GPU: RTX 2080 SSDSamsung 860 Evo 1TB
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476259
You will definitely get more than 200 FPS. I got around  340-400 FPS on my old R9 270, which is slightly less powerful than the 760Ti. That was in 1080P maxed out settings.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476277
What do you mean what do you expect? This is just stupid, if he wants an alienware than let him get it, period.
Well he can get much more powerfull and reliable PC for much less, all we want is to help :)
Also i7-4790 with 760ti? In gaming PC? What the hell alienware?
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476286
Serioulsy building PC is not hard, I knew nothing about computers few months ago and after watching only few videos I built my first PC, it was easy, fun and much cheaper, also biggest advantage of self built PC is that you get to choose every component, i5-4690K, GTX970 and only 8GB of ram is going to be MUCH cheaper and MUCH better for gaming :)
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476327
Guys , any suggestion for PC spec ? ( 2k Budget) :(  ( CSGO, COD , CODAW , B4)
yes we all do, make a post in new builds and suggestions
as a person who has both from dell/ailen ware i can say, you are far better off building yourself, they rip you off and use crap parts.
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476333
My vote is still to build it yourself. I have to head out and others will no doubt help you as I see pomaranc doing currently. Though I am going to leave this as a fall back plan.
https://www.cyberpowerpc.com/system/Gamer_Infinity_8800_Pro
Under Intel Smart Response Technology take the SSD option. It is a cache not the boot drive. It will just make the hard drive (stupidly) fast. The other is to change the power supply to Corsair or EVGA instead of some unnamed generic.
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476421
@pomaranc opps ,  i mean like you need to install the software for your graphic card right ?
Yes but it is very simple, you can also download geforce experience, it will download and install latest drivers for you, all you need to do is click install :)
Also you get 2 graphics cards you need to enable SLI in nvidia control panel :)
https://linustechtips.com/topic/329721-help-fps-on-csgo-d/#findComment-4476455
