And all of a sudden, BAM. 21.2GB free of 111GB
The only things I manually installed are software such as Steam or Chrome. I don't know how it has gotten so full. I have removed 1GB with CCleaner but dont know what else to do. Any help? Thanks ! :)
You got your steam games on it? Because if steam is on the SSD the steam games are installed on it as well. (unless you change the path to another drive)
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
remove the hibernation file
Nope, changed the path to my HDD.
Hmmm, do what @Jade said as well as @Enderman. They are good solutions
Hey LuLWaT,
You can move your pagefile to the HDD and try using the Disk Cleanup tool from the options menu in My Computer. Other than that I would recommend seeing what takes that much space in your SSD and manually moving or deleting it. It is recommended that you have 12%-15% of free space in order for the SSD to work optimally (caching purposes). The OS should take up around 35GB.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
Shrink your pagefile if you have a good bit of RAM
CPU  5820k - 4.0GHz @ 1.27V  |  MOBO X99-Pro  |  RAM 16GB Ballistic @ 2133MHz  |  PSU HX750i
 COOLING  Kraken X61 - 6x NF-A14 iPPC  |  DRIVES  256GB 950 Pro - 2x 1TB Travelstar - 1x 1TB WD Black
GPU  EVGA GTX980 SC |  CASE  R5  |  OS  Win 8.1 Pro  |  MISC   Cablemod C-Series White Set
  • 2 weeks later...
I think i may have found the problem.
http://gyazo.com/239d9b461c9fcbb03a579b489d9d86b9
 Hot diddly damn, shrink that sucker.
Or turn it off if you don't want it.
