840 evo questions
Go to solution Solved by flibberdipper,
Both of mine seem to be performing normally...
It slows down to protect itself if its dying.
So it just warns you to buy another ssd
(EZ MONEY 4 SAMSUNG)
Nvidia is to Dr Dre Beets as AMD is to KFC.
One makes you broke, the other you can get more of and have a midnight snack from the fridge when hungry again. Once you go Nvidia, you go broked, turn into an Elitist, or get the incorrect amount of VRAM.
- WCCFTECH
 I was only 9 years old. I loved Fifflaren so much, I had all the NiP merchandise and matches pirated. I prayed to Fifflaren every night before bed. Thanking him for the life I have been given. Fifflaren is love I say. Fifflaren is life. My dad hears and calls me a fuckhead. I knew he was just jelly of my passion for Fifflaren. I called him a Sw@yer. He hits me and sends me to go to sleep. I'm crying now, and my face hurts. I lay in bed and it's really cold. A warmth is moving towards me. I feel someone touching me. I feel someone touching me. It's Fifflaren. I am so happy. He whispers in my ear; "this is my pyjama". He grabs me with his powerful Swedish hands and puts me on my hands and knees. I'm ready. I spread my ass cheeks for Fifflaren. He penetrates my butt-hole. It hurts so much but I do it for Fifflaren. I can feel my butt tearing as my eyes start to water. I push against his force. I want to please Fifflaren. He roars a viking roar as he fills my butt with his love. My dad walks in. Fifflaren looks straight into his eyes and says; "He is a ninja now". Fifflaren is love, Fifflaren is life
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4454070
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4454071
Hello
I read somewhere that the 840 evo will slowdown after a while
That was a firmware bug and was fixed with an update. If you've had your ssd for a while i'd update it and run the magician.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4454083
Mine has been running for 5,846 hours and written 19.05 TB of data. It is still very fast and I have had no problems at all with it.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4454097
Well
1.7TB written
529 hours of work time
Sequential reads have dropped from a good 552 MB/s to ~485 MB/s.
Write speeds have remained the same
Random reads and writes have gone up though...
Never really bothered to check the speeds before but all of that happened in the space of 12 days so...
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4454955
Well the bug wasent fixed. Samsung is working on another fix right now...
Well
1.7TB written
Sorry for the late responds
so all of you guys did not do the firmware update?
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4456554
I honestly do not remember if I did, But apparently it was only partially effective.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4456614
Sorry my english is so bad :|
what is the meaning of partially effective ? haha
As I remember, it worked for a little while, but eventually wore off a little bit. Both of my 840 EVO's seem fine, and my 120GB EVO is still fine, despite the amount of data written to it and the power on hours.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4456927
There was a fix, but apparently there are some drives out there that it didn't completely fix.
One theory is that first batch drives use a different configuration for the NAND flash which the fix didn't account for.
Samsung is aware and waiting for another fix for those drives.
Those not having issues since the fix not need to worry.
There are PC Perspective podcasts addressing this issue on YouTube.
I applied the fix to my 250GB EVO and have not had slow downs since.
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4456956
According to Samsung Magician I'm using the latest firmware, so yeah.
Oh okay
so should i update it right now ? or updated when i'm starting some slowing down?
Thanks for the pic
so you updated your firmware?
and what is the max total host writes?
i only use it for 150 hours and the total host writes already has 411 gb
is that normal?
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4456961
Oh okay
Thanks for the pic
is that normal?
I honestly am not sure if I have, but I think I updated both of mine.
As for host writes, it depends what you do with it. Mine is still fairly low, but all I really do to this one is web browsing, and it's been through a few OS installs.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4456987
Oh i see
well, i bought mine in january 2015
so i think its the new one ?
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4456990
Ah i see
so if i updated mine when it starts to slow down, its okay right ? i just have to download the samsung restoration performance?
emm, my ssd is used for browsing, youtube, and OS, well right now i use it to play csgo also, because my hdd is broken
when my hdd comes back, i will put my games on that hdd again
but 150 hours mines already at 411gb
do you think its normal value ?
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4457022
Ah i see
It should be fine.
I'm assuming you copied a lot of games to it or something? Because all the host writes really tell you is how much crap you've written to it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4457055
It should be fine.
Hmm
what i installed on this ssd is
-OS
-Windows Update
-Drivers
-Steam
-CSGO CSSOURCE
-MediaPlayerClassic
-Chrome
-Firefox
-Notepad++
-AIMP3
and is playing games like csgo will make the ssd be written a lot of times ?
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4457097
Hmm
-OS
-Windows Update
-Drivers
-Steam
-CSGO CSSOURCE
-MediaPlayerClassic
-Chrome
-Firefox
-Notepad++
-AIMP3
It might if it saves stuff like user data and stats, but those tend to be small files. However, if you watch a lot of HD YouTube, then that can start to pile up. And I imagine Windows Updates will hammer it a bit.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4457183
Ah so the big concerns is
windows itself (windows update)
and yeah i usually watch youtube at 720p
so thats the main culprit?
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4457246
Could be.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4457252
But is should be fine right?
i read somewhere that 840 evo has 150tb limit of host total writes?
anyway
thank you so much for the help ! :)
It's fine. By the time the SSD fails, something else would have bit it or you will have upgraded.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/328041-840-evo-questions/#findComment-4457317
