Might have to turn up the volume a bit but it really bothers me sometimes when I'm just doing things where my headphones will distract me. I just want to know should it be the GPU or the the motherboard making that? It doesn't sound like its coming from the GPU. Considering I've heard this from my school PC's. Should I get a different MOBO?
https://www.youtube.com/watch?v=_FMkMrWC450
PCPartPicker Link To My Build
My YouTube channel, also check out my Twitch Stream!
Check out my Lastest CS:GO Video!
https://linustechtips.com/topic/327714-noise-while-idle/
Seems like it would be the GPU.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/327714-noise-while-idle/#findComment-4450699
Sounds like the one and only infamous coil whine.
https://linustechtips.com/topic/327714-noise-while-idle/#findComment-4450747
That's most definitely coil whine. I'd check the GPU and PSU first, then maybe the Motherboard.
https://linustechtips.com/topic/327714-noise-while-idle/#findComment-4450786
