My home system.
Go to solution Solved by Benielishackove,
Here are some more pictures of my system
The Receiver
post-193326-0-79937000-1426425469_thumb.
Subwoofer power amp
post-193326-0-87173600-1426425512_thumb.
Music mode
post-193326-0-90852400-1426425546_thumb.
Movie mode
post-193326-0-24402900-1426425568_thumb.
Subwoofer
post-193326-0-82364400-1426425623_thumb.
post-193326-0-44884700-1426425645_thumb.
post-193326-0-32952100-1426425651_thumb.
post-193326-0-67747600-1426425654_thumb.
Center
post-193326-0-61208500-1426425694_thumb.
post-193326-0-71263600-1426425808_thumb.
L\R Low (Bi amp)
post-193326-0-89549500-1426425736_thumb.
L\R high (Bi amp)
post-193326-0-93976800-1426425781_thumb.
Surround L\R
post-193326-0-78483900-1426425855_thumb.
and just in case
post-193326-0-36987800-1426426379_thumb.
Hey guys this is my system some diy non pro just value like system nothing special
https://www.youtube.com/watch?v=wapLfimS4B0
Hope u like it :)
Please don't trash.
sorry about the ipad microphone no under 60hz
more pictures down end page
Edited by Benielishackove
When i'm not playing PC games i'm playing with my PC parts  Fans,Pumps,Filters,  :wub:  :wub:  :wub:
https://linustechtips.com/topic/326903-my-home-system/
nice speakers :)
https://linustechtips.com/topic/326903-my-home-system/#findComment-4440314
how did you connect all of those?
its a 7.2 configure to be 5.2 with front bi amped
and the center is on 5-6ohm
the others are al 8ohms
the receiver handles 6-16ohms 150w at 6ohms so not that high sub the sub is 250w to 12ohms whooming and the ipad mic cant get that low
so I put I fan 120mm to cool it for the  center
receiver pioneer vsx923k
sub amp gemini xga-2000
https://linustechtips.com/topic/326903-my-home-system/#findComment-4440411
What is your goal?
To put as many speaker as possible into a tiny room?
my goal was to listen to music its a 7.2 so its not too many speaker for it
and if I could replace the walls with speakers I would
btw the upper silver Panasonic speaker is on mid range with the crossover so everything is setup right
there are no speakers that are connected to the receiver with no testing and no knowledge about crossovers
im not saying its the platinum award but value is good very value
https://linustechtips.com/topic/326903-my-home-system/#findComment-4452851
what, do you sit 3 feeet from the tv?? all the space in your room is occupied with those overkill huge ass speakers bro.
i have burned my 19" screen not long ago so im using the 32" as a pc monitor when i watch movies i place it in font of the center speaker as the bottom speaker is a radiator doesn't make sound and bass is bass goes thru wall if needed so the screen will be in front  (i will get a 50" if god will allow then i will make different arrangements to the center)
post-193326-0-25793200-1426345323_thumb.
https://linustechtips.com/topic/326903-my-home-system/#findComment-4453232
You calculated the crossover yourself?
Not bad doing it right is one of the most difficult things...
yep i used a web calculator an got the closest cap coils i could find and did a sound testing to see how it affects my woofer if the woofer is not moving that means that the twitter will not get bass
so i used a band pass 6db per octave for it with a big coil to filter the high freq and a 3.3uf cap  for the lows this is for the mid range
for the "super twitter" i used a 6db per octave high pass 1uf with zobel 2.2uf and 10ohm resistor
not pro but nice :)
sound ok stand out with all the others
https://linustechtips.com/topic/326903-my-home-system/#findComment-4453553
A web calculator OK.
Believe me the calculation of a crossover is way to complex for a web calculator.
maybe but i tested it with my own ears and eyes on a woofer to see the affects on a woofer\mid range (its not a pro way but you can listen to results and see the woofer moving or not)
https://linustechtips.com/topic/326903-my-home-system/#findComment-4454110
The Receiver
Subwoofer power amp
Music mode
Movie mode
Subwoofer
Center
L\R Low (Bi amp)
L\R high (Bi amp)
Surround L\R
and just in case
https://linustechtips.com/topic/326903-my-home-system/#findComment-4460197
