Hi!
I have to send my friend a text document but I don't have office so I'll be using notepad. So when he downloads it (will be sending it via gmail) his pc will use office word to open it, right? And it will look just like if I would have written it in word, right?
Thanks
Longboarders/ skaters message me!
https://linustechtips.com/topic/326806-quick-question-please-help/
Hi!
Thanks
It will open in notepad but he can right click and choose open with word..
If you save it as a .txt file your friend's computer will default to open it with notepad, but he can right click and open with to open it with word or any other text editor/word processor for that matter.
He won´t know how to do that, any way for me to save my file to something that his pc will automatically open with word?
You literally right click and press open with..
Tell him to open word first, then in word go to File>open (ctrl + o)  and point to the file from word is another option.
...your friend doesnt know how to right click and select something that says "open with"? Is your friend illiterate by chance? or have a broken mouse? Is he a potato?
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Windows should have another text program than notepad which works better.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
Hi!
Thanks
Why no Google Docs?
You mean WordPad I suppose?
I´ll tell him that. And maybe he´ll remember to right click etc. but I just want to save myself the trouble with explaining why and how...
I see your sig mentions potatoes...dont overclock your friend.
System Specs
Forgot the name :D
Main Rig
Phone
Save the file extension to.docx and all should be well.
You can rename/change .txt to almost any other extension. Only .xls won't work right because how Excel sees dividers. Instead you use .csv and while importing select which divider is used. I know this is beside the point :) Any text document format will work but it won't have any fancy editing included. Only font and font size.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
