Hello everyone,
My budget is $2500. and i need to buy a monitor and keyboard. I am going to be using it for gaming. I've decided on a couple of parts for each bit of the system. i am set on my monitor. but other than that. im open to 1 out of 2-3 opitions. NOTE: I wanna futureproof as much as possible.
1. CPU (I do not plan to overclock until i know how to do it safely)
a. i5-4690k ($319)
b. i7-4790 ($415)
c. i7-4790k (468)
2. CPU Cooler (Only if i got a K processor)
a.NH-D15($108)
b. NH-D14($88)
c. H110 ($175)
3. Motherboard
1. ASUS Z97-PRO (WiFi-AC) ($295)
2. ASUS Sabertooth Mark 2 ($255)
3. ASRock Fatal1ty Z97 Killer ($178)
IF A MOBO picked doesnt have WiFI. it will be around $40 for a wi-fi card/dongle.
4. Graphic's Card
a.Gigabyte GTX 970($525)
b. Gigabyte GTX 980 ($775)
5. Case
a. Thermaltake V71 ($205)
b. Thermaltake A71 ($185)
c Fractal Design Define R5 ($159)
6. RAM
a. 8gb 1600 ($98)
b. 8gb 2133 ($103)
c. 16gb 1600 ($185)
7. HDD
a. WD Blue 1tb ( $69)
b WD Black 1tb ($105)
c. WD Black 2TB ($179)
8. SSD (All 240gb)
a. Kingson HyperX ($159)
b. HyperX Fury ($185)
c.  Samsung 850 EVO ($165)
9. PSU
a. EVGA SuperNova G2 750W($145)
b. Corsair RM 650w ($175)
10. Keyboard
a. Coolermaster Storm TX Keyboard ($119)
b. ASUS Strix TACTIC PRO Mech Keyboard ($152)
c. Raser Deathstalker Expert T2 ($77)
The monitor is the ASUS MX239H. ($285)
Many thanks! :D
CPU:i7-4790k CPU Cooler: H100i Motherboard: Gigabyte Z97x Gaming 3 RAM: G.Skill Ripjaws 8GB(2 4 GB sticks) *UPGRADED TO 16GB(4 4GB Sticks)* GPU: Gigabyte GTX 970 G1 Gaming *UPGRADED TO Asus GTX 1070 Strix OC* PSU: Antec Edge 750w Case: Define R5 Monitor: Asus VG248QE *UPGRADED to a Acer X34 as my main monitor and my VG248QE as my secondary monitor* Keyboard: Gamidas Hermes *UPGRADED to a Corsair K70 RGB with BROWN switches* Mouse: Razer Naga Epic 2014
https://linustechtips.com/topic/326678-deciding-on-parts/
ok quick question, Are you actually going to be overclocking ? cause you can save a ton on MB and CPU but still get very high end stuff. Let me know and I'll advise you :)
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437152
1- 4790k
2- H110
3- ASUS Sabretooth
4- Gigabyte G1 970
5- YOUR CHOICE
6- 8gb 2100 and upgrade when u get the money
7- WD Black 1TB
8- 850 EVO
8b??- SupaNova 730w
9- None of them
CPU: Intel Core I5 4590 | GPU: EVGA GTX 970 SSC | Mobo: ASRock Fatality H97 Performance | Ram: HyperX Fury 8gb 1866 | SSD: Intel 520 series 240 GB | HDD: WD Blue 1TB | Case: Aerocool DS 200 red/black | Cooler: Coolermaster Hyper 212X | PSU: Antec High Current Gamer 620w | Monitor: AOC i2367fh & old HP | OS: Windowws 7
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437180
Where are you in the world those prices don't sound right
likely Australia!!!, lol (So Expensive)
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437185
 I will be, but not for a couple of years.
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437197
MSY in Australia.
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437200
We need to know where you are and if the monitor is included in the $2500...
Also using PCPP might help more...
The monitor is not included. so the budget is more like $2500- $285
PCPP?
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437203
I know right!!
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437204
PCPartPicker. Sorry :P
I dont think i can do that with MSY. :S
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437218
Comparative build:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($323.00 @ Centre Com)
CPU Cooler: RAIJINTEK TRITON 100.5 CFM Sleeve Bearing Liquid CPU Cooler  ($119.00 @ PCCaseGear)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($198.00 @ CPL Online)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory  ($175.00 @ IJK)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($149.00 @ Mwave Australia)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($72.00 @ Centre Com)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($479.00 @ Mwave Australia)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($129.00 @ PCCaseGear)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($145.00 @ CPL Online)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($125.00 @ Mwave Australia)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($19.00 @ CPL Online)
Monitor: AOC G2460PQU 144Hz 24.0" Monitor  ($369.00 @ CPL Online)
Total: $2302.00
Generated by PCPartPicker 2015-03-12 19:18 EST+1100
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437227
MSY?
Well, check this out:
http://au.pcpartpicker.com/p/Lb2cP6
It's 100 bucks over though...
I cannot buy online. i have to purchase at MSY as i dont want to purchase online.. :/
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437236
Comparative build:
Total: $2302.00
Ill have a look at those parts. :)
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437240
Point #1. Future proof/ing does not exist.
Point #2. What will you use the PC for?
1. I just want to make sure my pc lasts a decent amount of time.
2. Gaming, but i want to be able to do a bit of everything.
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437242
Don't be afraid of ordering parts.  You are likely to save some good money that can be put towards better parts, or saved.
Still, my parents wont allow me to purchase online. :/
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437243
Okay, then.  My budgeted build leaves $200 to spare... so you should be fine comparing those parts.
Thanks, ill definitely have a look at the parts. :)
https://linustechtips.com/topic/326678-deciding-on-parts/#findComment-4437247
