Ok so this has happened about 6 times now .
Randomly this happens, now when i restart everything seems to be fine
do i have a bad gpu or is this just a driver issue?
the card is a Gigabyte r9 270x with Catalyst 14.12
I posted a video of the issue
https://www.youtube.com/watch?v=onmXth1OZXY&feature=youtu.be
https://linustechtips.com/topic/326099-is-this-a-normal-problem/
Looks like a bad GPU :0/
...but get more opinions.
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4428958
Are you using a broken VGA cable perhaps?
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4428963
SNIP
Nope, something is definitely wrong,
You don't suffer any artefacting in games?
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4428965
^ try flexing / rolling/snaking the cable to see if you can eliminate this as a possibility?
But it does look like a failing GPU. Heat issues maybe (Looks like it could be a solder-ball problem).
Also, to answer your question more precisely: no, not a normal problem; probably not a quick fix :0/
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4428986
Someone yesterday in my class was doing this stuff with a monitor by bending it and bit and stuff
such weird
@pcgamer1999
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4429094
such weird
@pcgamer1999
He was getting that same effect?
It could be intermittent loss of parts of the signal or momentary disconnections. I was thinking more along the lines of it being the solder balls (that it's basically approaching the video card equivalent of a rrod or ylod).
The thing is, there are so many variables with this stuff that, it's hard to figure out using just basic deduction.
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4429382
It was not all of the effects, but he did have the flickering and the green and pink lines
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4429612
It could just be an effect common to both, but I think it's worth testing for it, who knows? You'd just have to be careful not to stress the socket where it's plugged into the graphics card (that alone could probably give you similar effects).
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4429637
There could be a few problems here, but it would try the following
1. check the cable is ok, swap it wit one you know is working.
2. check the monitor/tv doesn't have an issue, try the same input with a different device and other inputs if possible.
3. remove the GPU and test that the on-board graphics dont have the same issue, if there is no problem with the GPU out of the machine, then looks like it is the most likely culprit.
4. have you tried to OC anything recently? if so revert settings to default and try again.
hope its nothing major though buddy.
Cpu : AMD Ryzen 3 1200 (3.8Ghz), Motherboard : Gigabyte AB350 Gaming 3 - RAM : 8GB DDR4 2933 Team (Vulkan) memory, GPU : MSI GTX 980 4GB Case : Antec P50, Storage : 120GB Samsung SSD, 3TB WD Blue, PSU : 530w Thermaltake SPS-530MPC, Cooling : Artic freezer Pro 7, OS : Windows 10.
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4429675
Check for any bent cables on your monitor to GPU cable. Check maybe if monitor is the problem. If you overclocked the GPU, take it off or even try undercloking. If nothing happens RMA it.
https://linustechtips.com/topic/326099-is-this-a-normal-problem/#findComment-4429724
