Ok so when I'm playing battlefield 4 my card gets 200 fps after like 30 mins not all the time but occasionally the fps will drop to 20 fps like really low stuttering than the fan gets loud kinda like start up for pc than it fixs it self
I nevery used to get this so I don't know what's up I re installed drivers I even emailed evga and they don't know what's up can any one help
https://linustechtips.com/topic/325423-gtx-980-problem/
if you go from 200 to 240fps that is not called a drop...
https://linustechtips.com/topic/325423-gtx-980-problem/#findComment-4419770
I fixed it but im still having a problem
k which fan gets loud
your GPU fans or your CPU fan
https://linustechtips.com/topic/325423-gtx-980-problem/#findComment-4419840
Yeah there's no way that should happen. Do you live in a very hot place? How restrictive is your CPU airflow?
Intel 4790 K - R9 295X2 - Gigabyte Z97-SLI - Corsair Vengeance Pro Black 1866 CAL9 - Corsair HX 1000 -Samsung 850 EVO SSD - Samsung HDD - H100I - Corsair C70 - G400 Logitech - Asus VS247H - WASD custom mechanical and QCKPAD!
Staples of LTT: Getting an 4690 K will resurrect your lost family members, AMD = More heat thus AMD = Satan.
https://linustechtips.com/topic/325423-gtx-980-problem/#findComment-4466101
What are your system specs? CPU, RAM, etc.
Also try setting your Paging File size to "system managed".
Sorry for late reply....
Okay
Asrock Z97 pro 4
i7 47 90
Stock cooler but in canada it's pretty cool and pc is in basement so max temps are around 80 on a bad day
Gtx 980 sc
WIFI CARd pcie 8x I know it's old
8gb ballistic sport
sketchy 500w Thermaltake psu
https://linustechtips.com/topic/325423-gtx-980-problem/#findComment-4499050
Okay
Asrock Z97 pro 4
i7 47 90
Gtx 980 sc
8gb ballistic sport
Could be your PSU?
CPU: Intel i5-4690K @ Stock | GPU: Zotac GTX 970 @ Stock | COOLER:Corsair H110i GT Stock fans | MOBO: Gigabyte Z97-X Gaming 5 | RAM: 2x4GB GSKILL RIPJAWS X 1866mhz PSU: Silverstone 500W Strider Essential Series | CASE: NZXT S340 | CASE FANS: x1 120mm TT Riing red LED, x1 140mm TT Riing red LED MOUSE: Razer DeathAdder Chroma & Logitech G502 Proteus Spectrum KEYBOARD: Varmilo VA87MR Gateron Red Switches | HEADSET: Logitech G230 | SSD: ADATA 256GB SP900 HDD: 500GB WD Blue & 1TB WD Caviar Black OS: Windows 10 | DISPLAYS: ASUS VX239H and some shitty Samsung 720p
https://linustechtips.com/topic/325423-gtx-980-problem/#findComment-4499192
Could be your PSU?
Thinking that as well. You should NEVER cheap out on a PSU. Plus that wattage seems a little low for his system.
Project Cobalt:
CPU: AMD FX 8370 Motherboard:
Asus M5A97 R2.0
RAM: G.Skill Ares 16GB (2x8GB) DDR3 2133 GPU:
Gigabyte GTX 970 G1 Gaming Case: NZXT H440 (Blue)
Storage: Samsung 840 EVO 256GB +  2x 1TB WD Cavier Blue
PSU: Corsair 750G2
CPU Cooler: Swiftech H220X
Keyboard: Model M + a lot of others
Mouse: Logitech G502
Vintage Gaming PC: AMD Athlon T-Bird 800Mhz, Gainward nVidia Ti200 128MB, 512MB Crucial RAM DDR, Compaq ASPEN 2 OEM Board, Soundblaster Live! 5.1, Windows 98SE
https://linustechtips.com/topic/325423-gtx-980-problem/#findComment-4499232
Asrock Z97 pro 4
i7 47 90
Gtx 980 sc
8gb ballistic sport
The problem might of been caused by a memory leak from a recent BF4 update. PSU wouldn't cause those issues.
See this thread:
http://battlelog.battlefield.com/bf4/forum/threadview/2979150494049649652/
16GB of memory would help, and or make sure you have Paging File enabled.
https://linustechtips.com/topic/325423-gtx-980-problem/#findComment-4505034
