this shows you all the steps:
http://www.derivative-calculator.net/
https://linustechtips.com/topic/325274-calculus-help/#findComment-4417839
Chain rule it. So
Derivative of the outer (power rule) with the inner, times the derivative of your inner.
So the derivative of u^3 = 3u^2. Substitute cosine(x-x^3) back into u.
The inner function isn't a pure cosine function either so you have to chain rule that as well.
Derivative of cos(x-x^3) = -sin(x-x^3)*(1-3x^2)
Once again derivative of the outer function aka cosine with the inner function, the x-x^3. Times the derivative of the inner function (x-x^3) which is 1-3x^2.
3*cos(x-x^3)^2 * (-sin(x-x^3))*(1-3x^2)
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/325274-calculus-help/#findComment-4417904
