2 quick questions for python 3.x.x
Go to solution Solved by olbaze,
I also cnat find out how to make it loop after like it gave a result :/
Put lines 3-16 inside a while true block. That'll loop it until you force the program to close. If you want to implement a termination based on a special input, you can use while action != instead.
i know that you can get lower(string) in python 2.x.x but I cant find how to do that in 3.x.x
I am asking this because I have this simple calculator, however I want the inputs to be put in any lettercase (Uppercase or lowercase, or a mix of them) so that there will always be the output and people dont get an error when they put different 'case' letters. If i use if lower(action) == "multiplication" I get an error that says.
Traceback (most recent call last):
  File "C:\python\basic calculator.py", line 34, in <module>
    main()
  File "C:\python\basic calculator.py", line 7, in main
    if lower(action) == "multiplication":
NameError: name 'lower' is not defined
My second question Is how can i make the whole thing loop so i dont have to close the 'calculator' and then have to put run it again?
def main():    action = input("Division, multiplication, addition, substraction, square?")    n1 = float(input("What is your first number? "))     n2 = float(input("What is your second number? "))    if action == "multiplication":         print ("the product is", multiplication(n1, n2))     elif action == "division":         print ("the quotient is", division(n1, n2))      elif action == "addition":         print ("the sum is",addition(n1, n2))     elif action == "substraction":         print ("the difference is", substraction(n1, n2))    elif action == "square":        print (square(n1, n2))        def substraction(num1, num2):     return num1-num2                                                          def addition(num1, num2):    return num1+num2        def division(num1, num2):    return num1/num2  def multiplication(num1, num2):     return num1*num2def square(num1, num2):    return num1**num2main()
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
https://linustechtips.com/topic/323932-2-quick-questions-for-python-3xx/
try like this
str = "THIS IS STRING EXAMPLE....WOW!!!";print str.lower();
and you can loop using
while True:    codecodecode    codecodecode    blahblahblah
try like this
I get invalid syntax and it highlights str
My PC:
print is a function in python 3, it should be
print(str.lower())
edit: and no semicolons
Ok, however my problem is not in like printing lower case only, but making an 'if' that takes the lowercase of an input string so that people can enter for example MultipliCatioN, or Division, instead of multiplication or division.
My PC:
So instead of printing the result call .lower() on the string that is returned from input.
1474412270.2748842
Ok got it now thanks :)
My PC:
My PC:
I own and use, sorted from newest to oldest: SteelSeries 6Gv2. Microsoft SideWinder X4. Mionix Naos 7000. Zowie EC1 Evo. Microsoft SideWinder X8. Microsoft IntelliMouse Explorer 3.0. Dell U2414H. Samsung P2270H. AKG K273 Pro. Sennheiser HD555. Razer Goliathus Speed Medium. Func 1030 L. Qpad CT Medium.
I used to own: Razer DeathAdder 3G. Razer Krait. IntelliMouse Optical 1.1. SteelSeries QcK.
