So for the past couple weeks my h110 has been making a watering sound from time to time..It scares me to death so I always check my temps which turn out to be okay. So is this normal or should I get a new cooler?
CPU¤Core i5 5675c ¤Cooler¤Ghetto water loop(Cheap tubing & block from amazon)¤GPU1¤Sapphire R9 290x Tri-x¤MOBO¤Asrock H97m Anniversary ¤RAM¤8GB DDR3 1866Mhz¤Storage¤2Tb SSHD & 320Gb HDD¤Case¤Cougar Spike Mini ITX case¤PowerSupply¤500w EVGA 80 plus¤
https://linustechtips.com/topic/323514-is-water-sounds-normal/
wat?
vid pls?
maybe some air bubbles.
https://linustechtips.com/topic/323514-is-water-sounds-normal/#findComment-4396330
its just a bit of air bubbles that are inside the loop
when they go through the pump they make noise
it will not affect your performance, but it gets annoying
if possible, mount your cooler vertically and that should remove the noise
https://linustechtips.com/topic/323514-is-water-sounds-normal/#findComment-4396333
i dont really know what to say but this reminded me of somehting i always wanted...
a water cooling resivior that purposely takes water form the top and puts it to the mass in the bottom like how rainhead-shower heads do, loads and loads of dropets instead of a flow.
:3 for show if its managed properly would look cool and makes the perfect sound for me to fall asleep too. (should be able to be turned off tho)
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
https://linustechtips.com/topic/323514-is-water-sounds-normal/#findComment-4396352
