Need a Lil help with this program
Go to solution Solved by JamieF,
-snip-
-snip-
I'm bored so here's the code:
Public Class Form1    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click        Dim num1, num2, num3 As Integer        Randomize()        num1 = Int(Rnd() * 50) + 1        num2 = Int(Rnd() * 50) + 1        num3 = Int(Rnd() * 50) + 1        TextBox1.Text = num1.ToString()        TextBox2.Text = num2.ToString()        TextBox3.Text = num3.ToString()        If num1 + num2 = num3 Then            MessageBox.Show("Correct")        Else            MessageBox.Show("Incorrect")        End If    End SubEnd Class
Strange and kinda useless program though especially if you use numbers up to 50.
//Place this in a button functionif (Number1+Number2 == Number3){ TextBox4.text = "Correct";}else{ TextBox4.text = "Incorrect";}
This should help a bit
EDIT: wait, first you have to make the strings from TextBox1 and 2 into ints. Google how to do this in your program.
@Lexgium
it has to be random, my apologies didnt explained well, i meanif u introduce 30, 20 and 50, no mater in which one should say correct
in proper words the sum of any pair of numers
Qoute people when answering them.
I don't understand what you mean, could you explain again?
My apologies, well, when you run the program you introduce 3 different numbers, for example, 30, 20 and 50 you have to sum 2 of them and determine if the result is the 3rd number if it is the number the msg box says " correct"
@Minibois
So before you press the button, probably in the Start function or whatever (I don't do Visual Basic, so not sure) you just have to make 3 different  random numbers.
And when a button is pressed, or just after that, you have to run code similar to mine or @MatazaNZ 's code.
my code is similar to @MatazaNZ, but the sum has to be random, not the numbers,
num1 and num2 are random numbers, which have to be added up with each other and after that the code checks if it is the same as num3 (another random generated number).
After that num1 and num2 have to be added up and the code will check if num1+num2 equals num3.
If it does equal to the same, correct will be shown. If not, incorrect will be shown.
-snip-
-snip-
It was just a practice at class, thank you bot for answering, and thanks for the code
