How does streaming work?
Solved by Blade of Grass,
Just remember correlation does not imply causation ![]()
If you're transferring data to another computer on the local network, your Internet speeds do not matter, the speed of your local network does. This is because the packets will be addressed to a IP that would be in the router/switches tables, and it would deliver it directly. Even if the packet was address to your external IP, your router/modem would never send it out (it would say "oh! I have a packet addressed to myself, delivered!").
