I am having problems with my LAN on my laptop. No matter which port or cable I use I just cant seem to get connected to the internet. I tried disabling/reenabling, restarting the computer and flushing the DNS but they don't seem to work. When I check on the device manager it says the device is working properly. In the adapter settings window, it says that the "network cable unplugged" when the cable is connected.
Below are my specs:
Windows 7 64-bit
Realtek PCIe GBE Family Controller
Windows IP Configuration
Ethernet adapter Local Area Connection* 13:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
Wireless LAN adapter Wireless Network Connection 3:
Wireless LAN adapter Wireless Network Connection 2:
Ethernet adapter Local Area Connection:
Wireless LAN adapter Wireless Network Connection:
Tunnel adapter Local Area Connection* 14:
Tunnel adapter isatap.{3DDF1986-6608-4FF0-AE8B-889D35DE9C44}:
Tunnel adapter isatap.{EC44303A-2751-49A4-8126-4CD9F76EEFA8}:
Tunnel adapter isatap.{3F4DDC3B-181B-4173-AEDD-8E6897DAD198}:
Tunnel adapter isatap.{ED841A0F-EED5-49B0-A12D-88DAFCB60723}:
Tunnel adapter 6TO4 Adapter:
Tunnel adapter isatap.{F9EA328A-A6D5-4ACD-B870-1A6D58853FBA}:
I know i can use the wifi but i prefer to use the cable because it is faster and more stable since i don't have to share it with others. Please help. Thanks!
https://linustechtips.com/topic/320014-ethernet-lan-problem/
try reinstalling your LAN drivers
https://linustechtips.com/topic/320014-ethernet-lan-problem/#findComment-4349445
Are you sure that the Ethernet cable you are using works?
Yes. I have been using it since last year and I have tried switching both cables. Even used a different port but the results are the same. It also just disconnected while I was in the middle of using it. Happened last night as well but was ok after i restarted my comp.
https://linustechtips.com/topic/320014-ethernet-lan-problem/#findComment-4349485
Now another problem arose. It worked a while after reinstalling the driver but after putting it to sleep and coming back a few hours later it does not sense the drive at all. The device is not appearing in the device manager at all. When i try to install/uninstall the drive it says "the device is not found. If deep sleep mode is enabled please plug in cable." Help!
https://linustechtips.com/topic/320014-ethernet-lan-problem/#findComment-4350996
