970 would be a good card for this ;)
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/316787-video-card-help/#findComment-4305824
im doing a new build,,and want to use my 52in 120 hz tv,,,,im wanting to run metro laslight and othere newer games at 1080p ,,with a desent frame rate,,,what card can handel this?,,,thanks
No budget?
980 and you'll be safe.
Or 970 or 290X
https://linustechtips.com/topic/316787-video-card-help/#findComment-4305843
you guys know it's only 1080p right?
Obviously
980 IN SLI or r9 290x in Crossfire
Are you high? That'll go good for 4K. Overkill for 1080p
https://linustechtips.com/topic/316787-video-card-help/#findComment-4305916
