Hello everyone, this is my first post and I'm just looking for some quick help with which power supply I should purchase. Below is the components I have thus far obtained for my build.
Case - BlackHawk Ultra
Motherboard - Asus Crosshair V Formula-Z
CPU - AMD FX 8350 4.0GHz
GPU - Asus R9 290 Direct CU II4GB DDR5
RAM - G.Skill Sniper 16GB DDR3 1866Mhz
SSD - Corsair MX100 512GB
With that having been said, the main issue is that the GPU requires a six and eight pin power connection, as it can draw up to 300W. So I've been poking around NewEgg trying to figure out which PSU would be the best for this, with a budget of around $200 all-in.
I've been looking at the EVGA SuperNova G2 750W and I'm thinking that this is the PSU I should use for this build. If anyone has any other suggestions I'd be glad to hear them.
Thank you very much!
https://linustechtips.com/topic/316066-power-supply-indecision/
Welcome to the forums!
EVGA SuperNova G2 750 is the way to go for you :D
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/316066-power-supply-indecision/#findComment-4295458
750G2 is one of the best choices for the money. Definitely gets my vote as well.
"Rawr XD"
https://linustechtips.com/topic/316066-power-supply-indecision/#findComment-4295468
EVGA SuperNOVA 750 / 850 G2. I would personally get the 850 watt variant for headroom, but the 750 is just fine.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/316066-power-supply-indecision/#findComment-4295479
Too bad you already bought those parts... you could have done a lot better with that money.
Anyway, you can stick with a 600w PSU if you only plan on single config, or 850w if you'd like to add a second 290 in the future.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/316066-power-supply-indecision/#findComment-4295544
Awesome, thank you. If it's not too much to ask, I was looking at the Corsair H100i cooler and have that mounted on the fans that come on the front of my case. Would that work?
it doesnt come with two sets of long screws, so you eiher have to use the included fans, or use the fans from the front of your case, not both
https://linustechtips.com/topic/316066-power-supply-indecision/#findComment-4295554
Considering the size of that case, i don't think so.
Better put it up top.
https://linustechtips.com/topic/316066-power-supply-indecision/#findComment-4295555
