I liked this one racing map.. It is only really fit for 2 player multiplayer... I'll try to find it.
EDIT:
"Gelocity Time Trial - Track 3"
https://linustechtips.com/topic/314735-best-custom-portal-maps/#findComment-4278398
Theres custom Portal maps?
Portal 2 maps, there is thinking with time maCHINE.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/314735-best-custom-portal-maps/#findComment-4278405
Are there legit puzzle levels or is it just a bunch of crap like in garrys or the cs surfing stuff?
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/314735-best-custom-portal-maps/#findComment-4278423
I'd say the ones that get featured are probably among the best.
Yes, legit puzzle levels. Some of them are awesome.
Sig under construction.
https://linustechtips.com/topic/314735-best-custom-portal-maps/#findComment-4278427
Yeah, there are legit levels, someone did a prequel type thing where you explore the early Aperture Science, I can't remember what it's called though
"My game vs my brains, who gets more fatal errors?" ~ Camper125Lv, GMC Jam #15
https://linustechtips.com/topic/314735-best-custom-portal-maps/#findComment-4278430
I'll try it thanks :D
That's for Portal 2, thanks anyway
Oh, derp :P
I immeditaly thought you meant Portal 2 instead of 1..
It's still a fun map for P2, if that makes it any better..
https://linustechtips.com/topic/314735-best-custom-portal-maps/#findComment-4278504
Definitely look at Portal:Prelude and Thinking With Time Machine.
Aperture tag costs a couple dollars but it's pretty good too.
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/314735-best-custom-portal-maps/#findComment-4278851
