Upgrade 5870 -> 270x Noticeable difference?
Yes that will much improve your experience, may we see your system specs to insure there is no bottleneck?
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
Yes , I upgraded from a 5850 which is very VERY to a hd 5870 similar to a 270x and the difference is more than double.
Dont get a 270x tho , its bad value.
Get a r9 280 instead,
IDK, the 5870 was a beastly card 5-6 years ago.  270X is a lower mid-range card.  Jump to a 290.
I have (in an older PC) 2 5850's, the 5870 was much better than the 5850.
http://pcpartpicker.com/part/diamond-video-card-r9290d54gv2
It will be noticeable. But you should get an R9 280 since it's a better deal.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Thing is i don't want to spend a lot of money. I don't really need ultra performance. I just want to play Far Cry 4 on very high and coming GTA V with quite good performance. 60FPS totally not needed.
Get a r9 270 then for cheap.
If you are wondering to see how the card performs here is a list of benchmarks i did with my 270x
http://imgur.com/a/5LNqM/
Very good performer , keep in mind every game is utterly maxed out.
I heard that there is no problem with overclocking MSI 270 to 270x specs. True?
Depends on the silicon lo terry but its possible.
Blasphemy!
http://pcpartpicker.com/part/sapphire-video-card-1003732l
This is true most of the time.
What are the rest of your system specs?
Yes
So you can go up to a 290.  Now it is just your budget.  $180 gets you a R9 280, assuming you are in the USA.  Below that, go for a 270 and oc it.
I went from a 5850 to a R9 280,  15-20 fps in Crysis 2 (maxed, high res. texture pack), to 70+... 95% of the game.  It sometimes dipped below 70.
5870 is equal to a 250 these days
Core I7 5960X / Gigabyte X99 SOC Force / Kingston 16GB DDR4 3000 / EVGA GTX 980 Classified's In Quad SLI / EVGA 1600W G2
Core I7 6700K / Asus Z170 Maximus VIII Hero / Corsair 16GB DDR4 3000 / MSI R9 290X Lightning / EVGA 1600W T2
60 FPS IS TOTALLY NEEDED, how can you say 60 fps is not needed :o are you part of the pc master race??
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
