soldering help plz
Go to solution Solved by QueenDemetria,
So i bought a soldering gun 30w, silver bearing solder, and some 16gauge wire that i want to solder... it's not going well. It seems that the metal just refuses to take the solder when connecting to the other piece any help is appreciated.
You need to use solder flux.
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/309827-soldering-help-plz/
https://linustechtips.com/topic/309827-soldering-help-plz/#findComment-4211847
I think he is a she lol
@XTankSlayerX
He is very much a she
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/309827-soldering-help-plz/#findComment-4211903
https://linustechtips.com/topic/309827-soldering-help-plz/#findComment-4211934
