'' My Pc is now the new sun, of planet earth ''
Ridska here ,
i having MAJOR heating crisis over here and its not good . with in 15 minutes , my pc would be more likelyhood of burning my house down to a crisp.
within playing Warthunder for 15 minutes, it goas so hot , i can cook bacon on it.
so im thingking of 2 ( or more ) causes of the pc over heating :
1.the 140 mm fan case is not good enough ( keep in ind that the fan came with the case by Bitfinex ) and i need to replace it with a better one.
2.the placement of the computer need to be moved .
i got 2 120 mm fans on the front and a 140 mm fan on the back of the case .
although , im thinking that i have not configured the air flow of the pc ( cuz i dont know how to , please dont slap me ) .
and lastly i think the overheating issue has risen because of my tinkering in the AMD Catalyst control center .
leave a comment down below of what you think is the problem is and
stay groovie :D
post-144483-0-19370300-1423854927_thumb.
Edited by Ridska
(⌐■_■)
https://linustechtips.com/topic/309716-15-min-over-heating-issue/
-snip-
And which is overheating: CPU or GPU? And what coolers are on both (like, Hyper 212 EVO on CPU, XFX Double Dissipation on the GPU, something like that).
Edited by Blade of Grass
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
First off, you have to remove that link since it is against the Code of Conduct (advertising).
got a 960 STRIX series GPU , the cooller master heatsink should have no problem . i think the GPU is having issues .
(⌐■_■)
What are the temps on your CPU and GPU?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
currently iv downloaded HWMonitor and it says that the temp of the Gpu was at max  85 *C ( 185 *F )
What is it at now?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
45-46 C ( 112-113 F )
Not the coolest, but I don't think it should crash... Maybe take a fan and make it blow at the card and see if that makes the problem go away.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
FYi , forgot to mention that i have 4 fans but 3 is in use . 2 in the front , 1 in the back and a nother one in the heatsink . and the max temps that i had was in the SSD , that was in the 100 C temp. and gets loud as holy balls .
(⌐■_■)
How ?! look , i '' built this pc '' as in , i picked the parts and though the half way mark , some things went wrong and so i thought that if im going to make the same mistake againg , might as well take it to a place that they would assemble it. i hand picked the parts , i was parshally was part of the constuction .
(⌐■_■)
That is NOT normal for an SSD to reach 100C, unless I misunderstood you. You should have enough fans too keep everything cool, too. I am honestly at a loss, much as you are.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
^ This, my HDDs are hidden under the shroud with some airflow for one and none for the other, and they hit 28-31C... Does the SSD feel hot?
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
take a look at the pic please
I know it's reading off 100C, just see if it's hot or not when you put your hand next to it, it could just be a bad sensor on it, but it might actually be that hot.
any sugguestions ? My SSHD is under my SSD and the temps of the SSHD are better .
(⌐■_■)
Ridska here ,
stay groovie :D
TOUCH THE FUCKING SSD AND SEE IF ITS HOT STOP IGNORING @Darkman!
PEWDIEPIE DONT CROSS THAT BRIDGE
Cant , its too hot . and im being nice here so caps off .
stay groovie and be nice .
You don't know if it's hot until you touch it!!!!
yes i did touch it . how els would i know its hot or not ?!
Idk that's what I asked.
But idk what you g can do...
Its weird temps..
As said, you have enough fans to keep everything cool already. And its really unusual for SSD to heat up like that. They don't have any moving part which would suggest internal error. I'd RMA that one asap.
The GPU is also bit on hot side with 85C. You can aid that with extra intakes and maybe adding second exhaust too. What case are you using (sorry if it was mentioned somewhere already)?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
