I'm typically worried about getting liquid in my PC, and somewhat nervous whenever i have liquids near my computer, but this partially due to how we all need air to cool our rigs, so there will be an intake fan and a out take fan in most computers, these can be dangerous to a computer, as liquid can sucked into the intake fan, and distributed all around the case, thus destroying my computer. I'm basically just seeking a way to make sure this can never happen, or ask if i'm being over worried about the situation at hand.
Any suggestions?
Here's my case, and on the side is a giant intake fan. If i were or my friends/family were to by accident hit the soda towards the intake fan (by accident) would it effectively ruin my computer?
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
https://linustechtips.com/topic/307655-water-proofing-cases/
I'm typically worried about getting liquid in my PC, and somewhat nervous whenever i have liquids near my computer, but this partially due to how we all need air to cool our cases, so there will be an intake fan and a out take fan in most computers, these can be dangerous to computer, as liquid can sucked into the intake fan, and distributed all around the pc, thus destroying my computer. I'm basically just seeking a way to make sure this can never happen, or ask if i'm being over worried about the situation at hand.
Any suggestions?
I personally would be more worried about the tower falling over from where it is.
Water being siphoned into the case, I wouldn't worry about it unless you are having super soaker battles in that room. (Don't do that)
That being said if you are still worried you could put a screen "cage" around it... not the most elegant solution, but it'd work to prevent drops of liquid.
(It wouldn't stop a deluge, so be warned.)
The only true solution is being careful though.
Edited by Prastupok
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/307655-water-proofing-cases/#findComment-4180625
computer fans will not suck up any liquid unless the liquid is poured directly onto the fan or you are using a 3000+rpm fan
https://linustechtips.com/topic/307655-water-proofing-cases/#findComment-4180635
This.
That said, there was a dust proof/water resistant case Silverstone never released using an inch thick dust filter and anti spill guard's
https://linustechtips.com/topic/307655-water-proofing-cases/#findComment-4180900
