Switching cherry MX key switches
arodrake
I know it's possible to actually buy individual cherry MX key switches.
I was wondering if anyone has tried switching their keys? is it possible and is it difficult?
I'm thinking of switching some of my keys from brown to blue.
CPU: Intel 2700k (4.7) MOBO: Asus P8Z77-V DELUXE GPU: Sapphire Vapor-X R9 290X RAM: 16GB Corsair Vengence (1866) CPU Cooler: Corsair H100i w/ 2x Noctua NF-F12 Storage: 256GB Samsung 830 Pro SSD (Boot), 64GB Crucial M4 (SSD Cache), 1TB WD Black Cavier, 2TB Hitachi, 2.5TB Buffalo Sound Card: Xonar Essence STX Case: Corsair Graphite 600t w/ full acrylic side PSU: Corsair HX750 (individually sleeved)
Peripherals: Filco Keyboard (Brown) Razer Deathadder, Sennheiser HD595, Zalman ZM-MIC1, Steelseries Qck Mass mousepad.
Pics of my Rig
Hmm, this is actually a really good question. I got a spare Logitech keyboard i guess i can test it out with?! :o
I'm not sure how to tho, but i would guess it's not the best idea since everything is connected (If you know what i mean) ^^
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
It has been done but it's an extremely long and gruesome journey! You will need to resolder every switch from what I've heard so in my opinion, unless you are good with a soldering iron, don't do it.
Is this the real life? Or is this just fantasy?
there are how tos on youtube, it a ton of work. if you are good with a solder iron it's doable
In
 he swaps reds for clears. It's a complete tutorial. This guy does a lot of awsome stuff with mech keboards i suggest looking into his chanel some more.
i know digikey has cherry switches, at just over $1 each
so it will cost $100+ to redo an entire board.
if you have plate mounted switches, you have to remove the switches.
if you have pcb mounted switches, you can just take the keycaps off and open each switch and change the stem.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
Here is a guide to switching the switches.
This video is about the ergo clear mod but it has the same process as switching out any other switches. It takes a lot of time and tools. It is your decision though for you to decide weather it is worth your time switching them or just buying a new keyboard.
Current Keyboards: Ergodox w/ clears, Poker 2 w/ clears, Ducky G2 Pro w/ Blues
