UI/rendering with python? What is python actually good for?
Go to solution Solved by Sauron,
So it's not as capable as a language like C++ but is suitable for less complicated applications or making larger ones work?
So if I want to make a game... I should put learning C++ as a higher priority than Python?
Well, it all depends on what kind of game you want to develop. Space invaders can be done just fine, and with a lot less hassles, using python with pygame. Battlefield 4 won't happen on python though. I still recommend learning python first, it's an easy language and with it you can learn the base concepts of programming that apply to EVERY programming language.
For a while, I have been learning python with hopes for using it to make some form of game. But so far I have not encountered anyone in my college course (Including my tutor) using Python for UI or anything pixel based. (e.g. not defining a window size or loading images etc)
I have, however, played a game (Dysfunctional systems: Learning to manage chaos) on steam that has a lot of python files in its directory.
Is python capable but not in IDLE? What is pythons purpose as a language?
To make simple games with python you can use a library called "Pygame". Don't expect anything too advanced though. It works perfectly with IDLE.
The main purpose of python is scripting and writing quick programs to do some simple things in less time and with less headaches that what would be required to fire up visual studio, code in, say, C++ with the super-strict syntax and compile the project. It's used as a sort of glue between executables; the main executable will call a python script (a few hundred lines at most) which checks a few things and makes sure the component requested is launched with the requested parameters. For example, if the game's launcher needed to find out where exactly the game files were located before starting the game, it could lauch a python script that looks for the files and feeds the main game's executable with their locations.
sudo chmod -R 000 /*
Well, it all depends on what kind of game you want to develop. Space invaders can be done just fine, and with a lot less hassles, using pything with pygame. Battlefield 4 won't happen on python though. I still recommend learning python first, it's an easy language and with it you can learn the base concepts of programming that apply to EVERY programming language.
Ok, thanks.
I guess considering me and my friend were going to make an interactive, multiple ending book, we should use python and some xml files. (Tutor recommended using XML to store the content so I guess that's next after python)
Ok, thanks.
.txt files were just fine for me ^^ but if your tutor says so, go right ahead!
