ASUS PB287Q 4K Monitor Issue (30hz lock)
Solved by InfiniteRiotzz,
Have you tried looking in the monitor's internal settings? There may be a setting which controls the DisplayPort revision, set to v1.1 by default for compatibility reasons. Some monitors do this.
The issue is now fixed! All I had to do was go into the crappy monitor settings, and go to the system start up page and click "display-port stream", and then I clicked Display port stream and clicked "Display Port 1.2". Now the last thing I did was change 30 Hz to 60 Hz! Thank you all for helping!
