what case
Go to solution Solved by Enderman,
NZXT S340?
Hello so I am building my first computer, and plan to have a gtx 970 (I will oc) and a xeon 1231 v3 (no oc......). So I am looking for a red-ish case, (I have red theme, so black is ok too) which has a side panel. I dont realy care about included fans, as I will add them if not included. I have a max of 60-70 and would also like to see a USB 3.o header or too. If you know of a case like this, or a case with incredible value! then please inform me.
Thanks in advance.
https://linustechtips.com/topic/301234-what-case/
RED H440
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/301234-what-case/#findComment-4093716
NZXT S340?
https://linustechtips.com/topic/301234-what-case/#findComment-4093724
RED H440
Is that between $60-$70?
NOPE
https://linustechtips.com/topic/301234-what-case/#findComment-4093727
NOPE
$120 stretch your budget its one of the best cases around
1
https://linustechtips.com/topic/301234-what-case/#findComment-4093755
S340 hands down
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/301234-what-case/#findComment-4093764
Doubling his budget is not "stretching your budget"
https://linustechtips.com/topic/301234-what-case/#findComment-4093768
I like the S340 better...plus its half the price
https://linustechtips.com/topic/301234-what-case/#findComment-4093789
its only $120 i mean what the hell thats like nothing
1
https://linustechtips.com/topic/301234-what-case/#findComment-4093793
"That's like nothing" Not to all of us, some people have to stick to a tight budget, that's why he/she included a budget. Because that's what they can / are willing to pay
https://linustechtips.com/topic/301234-what-case/#findComment-4093819
Exactly. Not me, I have a 200$ case, but I see the point.
Get the new red/black s340
https://linustechtips.com/topic/301234-what-case/#findComment-4094232
I have a $150 case I get that, but yeah. They listed a budget for a reason
https://linustechtips.com/topic/301234-what-case/#findComment-4094586
