Is the system wattage that shows up on PC Partpicker's website accurate?
Dreadnaught: Intel Core i7 970 3.2GHz, Silverstone TD-02, ASUS Rampage III Extreme, Kingston Fury White 24GB 1866MHz, Crucial BX100 250GB + Seagate 2TB SSHD, AMD Radeon Sapphire R9 390 Nitro, NZXT S340 White, Bitfenix Fury 650W, BenQ XL2730Z.
https://linustechtips.com/topic/299507-pc-partpicker-system-wattage/
Mostly, what's the system?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
Relatively close. Don't forget your overheads. If in doubt, double check now, before you buy.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
tends to be conservative and underestimate. you need to remember everyone also tends to over recommend power supplies also. also have to factor in power supplies are not 100% efficient. if you could share your PCpartpicker im sure we could help!
link below
Yeah shoot us a link. We'll tell ya! :D
Take it with a pinch of salt. If you ask on the forums (full specs), people will be able to tell you how much power you need.
Good bet is take PC Partpicker and add 100 watts or so.
OK so here is the part list:
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  (Purchased For £0.00)
CPU Cooler: Fractal Design Kelvin T12 62.4 CFM Liquid CPU Cooler  (£146.31 @ Amazon UK)
Motherboard: MSI A88XM GAMING Micro ATX FM2+ Motherboard  (Purchased For £0.00)
Memory: Kingston Savage 16GB (2 x 8GB) DDR3-2400 Memory  (£114.52 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£79.00 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  (£289.99 @ Dabs)
Case: NZXT S340 (White) ATX Mid Tower Case  (Purchased For £0.00)
Power Supply: BitFenix Fury 550W 80+ Gold Certified Semi-Modular ATX Power Supply  (£89.59 @ Overclockers.co.uk)
Case Fan: Phanteks PH-F140XP_BK 85.2 CFM 140mm  Fan  (£14.57 @ Scan.co.uk)
Other: QNIX QX2710 LED Evolution II (£245.00)
Total: £1088.11
Generated by PCPartPicker 2015-01-28 00:34 GMT+0000
That PSU is fine, however that CPU will bottleneck the hell out of a 970 and that cooler doesn't fit in that case.
-snip-
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
How can you be sure it will bottleneck? And the cooler will fit The site has made an error I have the case and there is plenty of room.
Mine is a bottleneck for my 280, which is less powerful.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
That sounds strange to me, I thought it was at least a reasonably decent quad core.
Unless you can get a crazy OC on it, I can guarantee it will bottleneck,
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
That was going to be my plan of action anyway, thus the reasoning behind the AIO for a seemingly lower tier CPU. I went AMD because I want bang for my buck, I'll probably push this thing to it's limit.
I can't get any OC on mine with a cooler on par with a 212 EVO. I'd just go with a locked i5 if I were you.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
No OC will not help. You have a damn 970, why not 4690k?
Lets all ripperoni in pepperoni
amd cpus arent that great get an i5 it is millions times better
Oh really, I can guarantee u a fx 9590 beats ANY i5 in rendering. And in gaming, the FX 8x or 9x is only behind 5-10 frames. Thats not even a "million" times better
Depends what your playing at what resolution.
But if your playing 1080p-720p that card push a junk ton of frames persecondnd the CPU might not be able to keep up.
If your playing most games your CPU will have troubles pushing more than 70 Fps unless its not too CPU heavy.
Also You cant really run tons of Background apps all the time.
And in Planetside 2 (Incredibly CPU heavy game) You might get 30-50 Fps Small fights and 20-30 Medium and <15-20 Huge fights.
But you should be fine if you dont run youtube videos or something in the background.
A riddle wrapped in an enigma , shot to the moon and made in China
1st of all sarcasm second of all 10 frames per second is quite a big difference and yes it beats it in rendering but thats probably not his use pretty sure its for gaming
10 frames per second can mean choppy and smooth i dunno about you but i care about my games not running choppy and what the hell the processor your talking about isnt even the one he was going to get he was going to get the athlon
My Cheap But Good Rig: I7-3770s, Intel Motherboard (actually made by intel), 16gb DDR3, Nvidia Gtx 1070, 250gb Samsung 850 EVO SSD, 750gb HDD, Evga 500 BR power supply
Then say an Anthlon. Not AMD cpu. Gosh damnit, anything above 60 is smotth. So 60 and 70 is not that big of a deal dipshit
well unless you want to loose some of your computers performance and he got a 1440p monitor and if he wants to crank the settings all the way up with his 970 he might not be able to max out his game and get 60 fps and not to mention it is never a bad think to have ten more frames ten more frames would make a very nice difference in the future where games will get more demanding games and the 970 will have a harder time running games sorry but you are wrong
