Thermal paste quality
Go to solution Solved by Constantin,
Thank you all for ur help!
I will go for a mid range thermal paste and aply it next time i clean up my pc
it just doesnt feel right to put a 1.2 Euro Thermal paste :)
Hi all, i recently upraged my cpu cooler (Coolmaster RR-T4) and i applied  the Everecool thermal paste, one of the cheapest  in the market.
Should i go for something better, or this is fine as it is?
Thanks!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/297831-thermal-paste-quality/
Thanks!
it would help......
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/297831-thermal-paste-quality/#findComment-4043105
Thanks!
You're only looking at like a 4C max difference between that and the best stuff available.  Honestly, the stuff that coolermaster supplies with their CPU coolers might be better than the Evercool stuff.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/297831-thermal-paste-quality/#findComment-4043111
I live in Greece and in summer the temps are kinda high.
CPU temps are ok now thought.
https://linustechtips.com/topic/297831-thermal-paste-quality/#findComment-4043122
ya, you should be good to go then :)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/297831-thermal-paste-quality/#findComment-4043132
Things that bug me (but not enough [normally] to post ) No 453:-
"only a few degrees difference"
Order of loop ~  "only a few degrees"  (still can't see why that would matter at all).
Quality of thermal paste ~  "only a few degrees"
Diameter of WCing tube ~ "only a few degrees"
adds up after a wee while.
And yet in reviews etc cooler A gives (say)90° at full load versus cooler B giving 92°, cooler A is considered to be so much better.
Why does "a few degrees" not matter until deciding A or B.
  Surely deciding between A and B (who perform at the 90 ~ 92 region) should be based on looks/cost/ease of install etc
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
https://linustechtips.com/topic/297831-thermal-paste-quality/#findComment-4043163
https://linustechtips.com/topic/297831-thermal-paste-quality/#findComment-4043453
